Thread Tools | Search this Thread | Display Modes |
#1 | ||
Severe storm and tornado warnings
__________________
Sean in Dalemead, AB Black 2000 Ram 2500 QC Auto 4WD with CTD, Posi-Lok CAD, DSS and Edge Insight.. |
#2 |
Pickin on the wrong admin...
Yes...I was listening to the weather alerts on the radio...I'm south of Calgary and could see that nasty cloud in the North end of Calgary..
__________________
1995 Dodge,280,000 miles, regular cab dually,4X4,5 speed,4:10 gears,Wastegate blocked,15 degree timing,Polyurethane control arm bushings,BHAF,KDP Tabbed,Pyro & Boost,DSS,2003 trackbar upgrade,Steerring bushing,#0 plate,3K springs,215 injectors,Laser cut DV,Con OFE. Mar 2008, Dyno: 353HP/735 Ft Lbs June 2008 Dyno:344HP/835 Ft Lbs 1978 Mercedes 450SL 1956 Chev 4 door Sedan 1977 T/A 400,4-speed 1963 Ford Falcon,2 door |
#3 |
I left Airdrie and was heading north around 6:30. I never got hit by much more than a sprinkling, but I could see the storm that was up around Olds, you could see the hail in the clouds. I headed out towards Sundre, there was still some hail in the ditches.
__________________
'98 3500 4x2 Quad Cab, 24v, 5 spd, 3.55s, CDS 13mm, SDX 7x.012 Injectors, Single S480, Big Stick Cam, FASS, BD Short Shifter, SBC DD, Fluidampr Alcoa Magnums, GM Brake Cylinders, HID Headlights, DSS '98 2500 4x4 Reg Cab, 12v, 6 spd, 3.55s, 0 plate, 4k GSK, 18° Timing, SBC DD, F1 370's, GT37R/GTX42R Twins, Fluidampr Alcoa H2's, Lorado Tonneau Cover, HID Headlights, Espar D5, EMS Hub Conversion |
| Display Modes | |
