Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > 1st Gen. Ram - All Topics
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 05-27-2004, 11:56 AM   #1
bigred496
Will a Second Gen Intercooler Fit on my Truck
I found a decent intercooler off of a second gen and i was wondering if it would fit on my truck, my truck came from the factory cold air challenged and i will be adding a bhaf in the near future, i am also in the process of aquiring an hx-35 for it, i feel that if i added an intercooler also, it wouldnt hurt, will this one fit on my truck?
__________________
BROTHER: 1991 W-350 (SRW) Non-Intercooled, Getrag 5 Speed, 4" Exhaust, ISSPRO Boost and Pyro on Pillar, Minor Pump Tweak,
MINE: 1999 2500 QUAD CAB, NV5600,2 INCH LEVELING KIT, 16X8 HELO MAX, 305/70R16 NITTO TERRA GRAPPLER
DAD: 2004.5 3500, QUAD CAB SB, EVERY OPTION BUT LARAMIE(DAD DIDNT WANT LEATHER) NV5600, Bone Stock but this baby moves
MOM: 2006 BMW 330i Silver on Black, Sport Package, Premium Package, 6 spd. Loaded
bigred496 is offline   Reply With Quote
Old 05-27-2004, 12:12 PM   #2
jiMMyCTD
jiMMyCTD's Avatar
there was a thread on tdr with a guy who installed one.
http://www.turbodieselregister.com/f...hreadid=102653
jiMMy
__________________
Tow Rig: 99 CTD/Club Cab/4x4/5sp/80HP injectors/xmonitor/afe intake/Edge hot comp/4inch with a muffler/Vulcan bigline relo kit/315 75 16s w/ level kit/Bilstiens up front/pac brake/mag diff cover/Ride Rite Airbags
Old Girl is Gone 92 CTD/4x4/auto OD/2 turns on fuel screw/POD's/3200 RPM Gov Spring/PDR Custom Fuel Pin/Autometer Diesel tach, pyro(pre-turbo), trany temp, and boost/BHAF w/ direct flow to turbo/H1C/16cm/4in stright pipe
jiMMyCTD is offline   Reply With Quote
Old 06-01-2004, 09:19 AM   #3
Redleg
Redleg's Avatar
Not experienced, but thinking out loud.......
If you are using the smaller up/down flow radiator, the heat transfer from the inner cooler might cause it to run warmer. You might consider changing to the larger cross-flow since you have to cut into the core support any way.
__________________
MIDTR
90 W350, flat bed, xtra leaf all around, Jasper 3spd auto, 16cm housing, tampered pump, Isspro pyro/boost, piller pod, BHAF, 93 radiator mod, Superwinch lockouts, Moog, 2nd D70.
The number you have dialed, 9-1-1, has been changed... to an unlisted number.
Freedom is everybody's job!
Redleg is offline   Reply With Quote
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
