Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > 24 Valve Engine and Drivetrain
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 05-26-2011, 10:27 AM   #1
CORed
Question Search broken - fuel filter question
I need a couple new fuel filters for my truck (see sig) and I see that Genos says the FS19855 is the Fleetguard replacement for the older FS19579 which I currently have one left.
So I picked up a 19855 from the local truck shop and it's different - the bottom (or top?) is completely closed with a plastic plate.
Can someone please confirm for me what's up? Again, search is not working this morning - just get a blank page in both IE and FF.
Thanks much!
__________________
2001 QC 2500 SB 4x4 5-speed, #53 block, RV275s, CSS +2" coils, Bilstein, MBRP, DSS, Isspro and Westach, GM cylinders, Walbro, Thuren, XZT+ with 3000_beta tune
"If you're lucky enough to get into the mountains... you're lucky enough!" - Thank God for COLORADO!
CORed is offline   Reply With Quote
Old 05-26-2011, 12:25 PM   #2
madhat
Administrator/Jarhead
madhat's Avatar
Click on Search, then click on the Advanced Search, then when that screen loads, use the google tool bar to search...
http://www.dieseltruckresource.com/dev/search.php
__________________
04.5 3500 4x4 Tranny, turbo, injectors, studs, springs, CP3 mod, smarty, MP8, Air Dog, 5" TBE, some other things... 868/1778
madhat (at) dieseltruckresource.com
madhat is offline   Reply With Quote
Old 05-26-2011, 03:58 PM   #3
Shovelhead
Administrator / Scooter Bum
Shovelhead's Avatar
From the Old FAQ tab in the Page header:
http://www.dieseltruckresource.com/f...rt_numbers.pdf
Hope that loads... it will give you all the frequently used part numbers.
fs19579 should be the correct fleetguard number for an '01
__________________
Ed Anderson
'99 3500 SPORT Black
Totaled 8-16-2012
Now 2012 Ram 1500 Quad Cab
5.7 Hemi Powered
DTR Site Moderator
If you find yourself in a fair fight, your tactics suck.
Shovelhead is offline   Reply With Quote
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
