#1 |
Runs too cold.
This is probably a no brainer ..but.... do these trucks tend to run cold ?
I have a '99, 4X4. When I run my truck in cold weather, going downhill on a long grade , no throttle, the coolant temeprature pegs out LOW. Cold. Is this normal or do I have a stuck thermostat ? (I am STILL impressed with the massive cooling system in these trucks.) Thanks in advance for the input. DEW
__________________
98.5 4X4 , Quad cab, long bed ,white as can be , 5 sp. Edge chip , 4" exh , K&N , silencer ring gone, head-ache rack, purple haze light to light up the license plate, big fat mud flaps. |
#2 |
Do you have your radiator blocked off? Yes, these trucks run cold when not worked. When I had my 2000, I ended up replacing the thermostat. If you do that, only buy a original Cummins part, expensive but they work.
__________________
2007.5, 2500HD, QC, Laramie, 4X4, SB, 68RFE, 3.73, Inferno red, Edge Insight w/pyro, MaxBrake, Firestone Ride-Rites and controller, Air-Zenith air compressor, EZ Change Drain plug, S&B drop in air filter, 250 watt oil pan heater, EGR unplugged. 2008 YZ450FX, matching 756's, Marcel Fournier ice tires, 320mm EBC supermoto front disk, billet fuel screw, DiD narrow x-ring chain, Ironman sprockets, Scotts SS oil filter, Dr. D pipe coming, love the SSS suspension... |
#3 |
you said 99 but below says 98.5. but anyway. if you have never replaced the thermostat or dont know if it has I would for safe measure. normally there is a 180 or 190 degree one. but if your going up and down I-5 up by like shasta with cold temps I can see a little colder but shouldnt be moving the needle drastic. check with the thermostat and go from there.
__________________
2002 HO 6-SPD LB 4X4 QC HTT 62/14, SB-DD3600, TST PM3/*REVO-BETA*SMARTY MACH 4'S, RINGED W/ STUDS, AFE/2 " FTE 6" STACK D/PRICOL GAUGES, FASS 150,1/2 DRAW-STRAW, DSS-BOX DT PRO-FAB TRAC BAR, CONV-T STYLE STEERING,DUNKS TRACTION BARS, AIR BAGS,17'' KMC BLACK HOSS, 37" TOYO MT'S 6" LONG ARM LIFT.THANKS RIP@sourceaumotive. US.MARINE PROUDLY SERVED 1993-2006 |
#4 |
Yea, its a 98.5, just rounding it off a bit. And you are right , Shasta / Trinity area.
My radiator isnt blocked off. This thing just should not peg out low , yep its probably stuck open a bit. I will go with Cummins a part. Out of curiosity, what is the down side of of it running cold other than my cab heater puting out cold air ; ) Any performance issues ? I have seen big-rigs with their radiators covered so there must be perf problems when they are too cold ? |
#5 |
Diesel engines are more efficient when warmed up to the proper temp. Everything is seated properly and the fuel/air is being compressed and burned properly. It's also easier on parts to have the engine all warm and cozy.
__________________
2001 Dodge Ram 2500 CTD QC SB 4X4: Goerend Trans with Billet Flex & Billet Input / Airdog 100 / Gauges / ScanGauge II / BHAF / Draw Straw / HTT Exhaust Manifold / 4" Straight to 6" Stack / Smarty & TST PM3 Comp Stack / DDP Stage 3's / HTT 62/71/14. |
#6 |
When coasting downhill you are burning NO fuelat all. The engine is just pumping air through. So, it has to cool down some.
__________________
2001 2500 White long bed Quad Cab Sport ETH/DEE All options except 4WD, CD changer and Auto trans. Didn't want those! 144,500miles. Replaced lift pump twice. Geno's big line kit. Also replaced left license bulb. . First set of Michelins lasted 97,681 miles. |
#7 |
yes true. at no throttle coasting theres no fuel injected at all. but with low cylinder temp when you do inject fuel it is not a complete burn you will eventually glaze the cylinder wall. which will be bad. burning oil, loss of compression.......you just dont want that.
__________________
Luke --------------------------------------------------- '97 Chevy V3500 CC DRW 6BT 22" Alcoas '98.5 24v 2500 QC 5spd 4wd Demon hot-rod *sold* '90 VW Jetta 1.6L oilbrnr 5spd coupe wolfsburg '73 RS/Z-28 Survivor. |
#8 |
I just ordered a new 'stat' from Cummins West. (180'F)
Dodge dealer wanted $72, ???????? Thanks but no thanks Dodge.Cummins sold it to me for $33, shipped to my house. Last edited by dewclaw : 11-11-2009 at 03:20 PM. Reason: left out info |
#9 |
This thread caught my eye. Mine's always run cold like that. I replaced the tstat and it performs the same. Either mine just runs cold or the sending unit or gauge is off.
Brad
__________________
99 Ram 2500 CTD 4X4 QC Long Bed, 47RE w/ Goerend parts and 3 disc TC, Smarty, Jammer 5's, II PS62/12, Dipricol Pyro, Boost & FP gauges, Homemade Walbro Fuel System, Amsoil 4510 air filter, 4" Exhaust w/ Donadson M085171 muffler, 3.55 gears, 285/75/16 Goodyear Silent Armors, Westin step bars, GM 1 Ton Wheel Cylinders, LarryB's Starter Contacts, Bilsteins, 300k miles and counting. |
#10 |
so whats a good temp? mine runs about 160
__________________
99 QC LB 24V DRW TRAIN HORN, EDGE EZ, SINGLE TO DUAL EXHAST 4" |
#11 |
190-200 on my truck is normal.
__________________
2004.5 Dodge Ram 3500 Quad Cab SLT AKA Blue Thunder 48RE Trans w/Mag-Hytec DD Pan @ Temp Gauge Rhino Bed Liner/Westin Nerf Bars 18K Reese Signature Hitch Viper Security System 50-Gal Aux. Fuel Tank 2003 35' Cardinal Fifth Wheel -AKA Motel 9 |
#12 |
put a 180 in mine. Found that the old stat had one side of the 'perch' that holds the spring, cracked in half . Holds solid at 180 now. It does seem to run more efficiently now.
By the way, I just turned 300K miles on the truck today ; ) |
#13 |
ok im scared now... my truck usually runs just above the 145 mark all the time. is this bad?????
#14 |
throw a new thermostat in and all should be golden, usually if they run cols the thermostats opens too soon, engine is more efficent when up in the 180-190 range. mine runs 190+ all the time except in extreme cold temps does it cool down,
__________________
Nick 2001, 2500 Edge J/A Hot unlocked,Magna flow exhaust. HX35 Jammer II's. BHAF, Airdog 150,DSS,3rd gen Track Bar. Carli Suspension, 3rd gen Brake upgrade, transgo Shift Kit. Firestone AirBags May 07 297,000kms Dec/09 473,000kms RETIRED Military Mechanic (20yrs) |
#15 | |
Quote:
1- you are driving short trips and the engine does not have time to warm up. 2- If the radiator is not blocked off, it will take longer for the engine to warm up (do this when it gets cold and stays cold outside) 3- you might have possible thermostat and sensor issues 1 and 2 can affect each other. Short trips, cold air, and an open radiator will definitely make the engine take a lot longer to warm up. Try this, drive your truck around for about a 1/2 hour and see if it comes up to temperature. Even when it is 40ºF outside, my truck will come up to full temperature with an open radiator (takes a little longer but it will). If it still does not warm up then start looking into possible thermostat issues. If you have never blocked off the radiator, it's pretty easy. I personally use a large sheet of cardboard, and slide it in between the intercooler and radiator. Works good, and I've been able to use the same piece of cardboard for 2 years now. Good luck, and let us know what you find.
__________________
J.R. U.S. Coast Guard , Electronics Technician 1st class Extra class Amateur radio operator - K5DTR 2001½ SLT 2500 2WD, auto, short bed Hi-flow banjo bolts Scotty Air II with the cowl hole and no silencer ring ! Isspro EGT (pre-turbo),fuel pressure, boost, and transmission temperature (sensor in hot line) guages |
| Thread Tools | |
| Display Modes | |
