Thread Tools | Search this Thread | Display Modes |
#1 | ||
Royal Purple ok for 03 5-Speed?
__________________
Aaron of Gallatin,TN 2003 Dodge 2500 4x4 NV4500, 5" Stacks, Tough Country front & back replacments and headache rack with Line-X, 285/75/17 Toyos, Raptor 100 pump, AFE Torque Tube with Amsoil Drop In(No more CAI), Silencer ring gone, Lorenz Coils and Extended Links, DSS Brace, Bilsteins all way round. Amsoil 15w-40 and Amsoil'd throughout |
#2 |
Some folks use Amsoil atf, but not Royal Purple, that I am aware of...though I am a big fan of RP products. Dodge is pretty picky about atf, and the ATF+4 is only available from them...I buy it in gallon jugs on Ebay, and it works out to less than $3 per quart, I think...
I can't speak to the transfer case, since I have a 2wd, but I don't think ATF+4 is required there, not sure though
__________________
2004 Ram 2500 QC SWB Cummins HO 04.5 325/600 Automatic 4X2 3.73 Champaigne & Silver Ventshade Window Visors DiPricol White Face Gauges (boost, trans temp & EGT) Extang R/T tonneau cover Black Nerf Bars Reese 16K Slider 5th Wheel Hitch 2005 Pilgrim 274 5th Wheel |
#3 |
The NV5600 (6spd) uses a different oil than the NV4500 (5spd). Here's the recommended oils for the 5spd, 75W-90 Castrol Syntorque Synthetic,
Mopar Manual Transmission Lubricant (PN 4637579) and GM Transmission oil (PN 12346191). MikeyB
__________________
2003 2500 2wd SWB Quad Cab Laramie, 305/555, NV5600, 3.73LS, Line-X, Westach boost/EGT combo gauge, PML diff cover, Airbox mod, Hurst 6spd Shift ****, Adjustable boost elbow, Toyo OC AT 285/70/17 E, Daystar 1.5" lift, Monroe Reflex, Raptor RP100, Lazarsmith Intake Horn, HID SMARTY Sr./Van Aaken C3.2 |
#4 |
The OEM Castrol Syntorq LT is actually a 75W-85 GL4 lubricant. Available from standardtransmission.com for I believe $54 a gallon.
Redline offers full synthetic GL4 transmission lubes, and they recommend a 50/50 mix of their MTL/MT90 to get the desired viscosity for the NV4500. A new player called Specialityformualtions.com also offers full synthetic GL4 manual transmission lubes, and their MTL-P is a direct replacement for Syntorq. It's $28.95 a gallon. GL4 rated lubes usually contain 1/2 the sulfur and phosphorus found in GL5 lubes. This is done to preserve the yellow metals found in transmissions, and to allow proper synchro function. Some synthetic manufacturer's will say their GL-EVERYTHING lubes will work fine, but you may find them too slippery for proper synchro function. GL5's are intended for final drive axle differentials. I use 4X4 quite a bit in winter plowing snow, and judged by the visible wear metals I've found in the drain ATF, I decided to search for something more robust. That's how I found Speciality Formulations, and now use their MTFGlide in the T-case. It's basically ATF, but with 5 times more anti-wear additives. It's also a full synthetic, and is $28.95 a gallon. The NV4500 holds 4 quarts, and the NV241 standard holds 5 pints. The HD version holds 6.5 pints.
__________________
'98.5 black RAM2500 C24VTD Clubcab SLT 4X4 SWB NV4500 3.54 RLSD Lund bug deflector and sunvisor silencer ring removed Westach A-pillar mounted fuel pressure and combo boost/EGT gauges Boss 8'2 V-snowplow Borgeson steering shaft American Racing aluminum rims Jacob's E-Brake Darin's Steering Stabilizer MBRP 4" SS Exhaust BHAF RV275 injectors FASS DDRP |
| Display Modes | |
