Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > 24 Valve Engine and Drivetrain
Register FAQ DTR Store Members List Mark Forums Read
Thread Tools Display Modes
Old 11-20-2009, 12:40 AM   #1
72 Suburban
Rods and Pistons England vs Mexico
What is the difference between the rods that are made in england vs rods made in mexico? I been looking at a set of 6 on ebay. The rods and pistons from england are 180 while mexico rods and pistons are 80.
Also is there a difference between rods and pistons of a HO vs a SO?
Chris
__________________
Chris
72 suburban 1 ton 1990 cummins, 2nd gen intercooler, pods, dtt 47rh 89%, PDR ve w/3200, 4" exhaust with 4040 aero turbine, Coming soon custom intercooler tubes, airdog, hx40
72 Suburban is offline   Reply With Quote
Old 11-20-2009, 01:24 AM   #2
6speedcowboy
6speedcowboy's Avatar
HO pistons are a little bit higher compression ratio. be better with the lower compression SO pistons if you are looking to make some power with the motor
__________________
2001 Dodge 2500 P-Pumped 24 valve DDP, South Bend, AFE, FASS, Scheid, BD, Snow
6speedcowboy is offline   Reply With Quote
Old 11-20-2009, 09:43 AM   #3
SIXSLUG
SIXSLUG's Avatar
Thats a good question on the rods. Mexican blocks are supposedly a little harder and sturdier than the others metallurgically. I am not sure who or where the internals came from though.
Kurt
__________________
Kurt
2001.5 2500 QC LB 4WD H.O. 6-SPD SLT Laramie Plus
Arctic White,3.54's, Camper/Tow, Stull SS Running Boards, A.R.E. Cab-Hi Canopy w/ SS Vanguard rack, Southbend clutch and hyd.,Power Service, BHAF/Heatshield, MBRP 4" TBE, FP Gauge, Femco E-Z Drainplug,DSS, Thuren Trac Bar, 2" leveling kit, P/H Tow Mirrors, new intank LP @80K, 95K miles.
Good judgment comes from experience, which often comes from bad judgment: W. Rogers
Support Our Troops! NRA, MSBL, BYO, GSP
SIXSLUG is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.6.7
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2003, DieselTruckResource.Com
