Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > 2nd Gen. Dodge Ram - No Drivetrain
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 03-29-2009, 06:36 PM   #1
vans33rr
Location: north west connecticut near the ma berkshiers
Replacing brake lines in a 01 ctd
I have a 2001 Dodge ctd 2500 qc sb that w/135k in the winter of '09-'10 (I live in the north east USA) I'm redoing the pickup from the ground up. The problem is the main brake line going to the rear blew and after further inspection I have to replace all the lines and some other stuff like the rear valve for the abs. I order some SS tubing from summit with large selection of fittings but none of the the fittings are the same. Part stores have some of the sizes and I'm sure MOPAR will have them but not in SS. Classic tubing has something thats close in all the brake lines but not exact. I want to fix this one time and be done with it. All the crazy sizes in the fittings is really messing up what would normally be an easy fix. I'm hoping to find someone who has come up with a good solution that makes sense. Any ideas would be greatly appreciated. Thanks for your time -Dave
vans33rr is offline   Reply With Quote
Old 03-31-2009, 12:32 PM   #2
wlowe
EGR is now selling OEM pre bent hard line brake kits for Dodge trucks. They come is Stainless Steel or mild steel. Here is their website:
http://www.egrbrakes.com/index-main.htm
__________________
2001.5, 2500, QC, 4x4, Auto
Isspro EV's (Pyro, Trans, Boost)
Dakota FP Guage
Stull Running Boards
Mag Hytec Rear Cover
DSS
Firestone Bags
PullRite Hitch
Carter Pusher
2WL
BHAF
MBRP 4" Exhaust
Frantz
Biltein 5100's
ProWeld Trans Cooler
Edge J/A
68,000 miles
wlowe is offline   Reply With Quote
Old 03-31-2009, 10:42 PM   #3
SWC
A second vote for EGR. If you call EGR you will probably talk to Glenn Maurer himself.
Stan
__________________
01.5 3500 ETHDEE 4X4 3.55 diff, Patriot Blue, Lost the dually box replaced with custom steel deck (black when freshly painted), Edge EZ, RV275's, Southbend clutch, Pacbrake, Pinnacle 4" turbo back exhaust, Bilstein 5100 shocks, RideRite airbags with onboard air, Fast Cooler, Mag Hytec rear diff cover, Isspro Pillar mount EGT, Boost, Fuel gauges, Scotty's smart fuel line kit, BD 2 wheel low kit, Light Force lights
SWC is offline   Reply With Quote
Old 04-01-2009, 02:57 PM   #4
kawi600
kawi600's Avatar
Nice stuff but not cheap. I just did the usual hack with a couple unions and some tubing. Water gets trapped up beside the tank and rots those lines.
__________________
95 Ram 2500 220k mi, DTT auto w/ 4 disc converter, PS62/12, 4" exhaust, AFE filter, rebuilt 215 pump, TST AFC kit, #10 plate, 181 DV's, 7x.010 275BAR 148* Injectors, GS3K, 18*timing, Hamilton 210/181 cam, springs, pushrods. Hamilton 12v head, 625 studs, orings, snow water/meth
Dont blame me, I supported Ron Paul
Toute nation a le gouvernement qu’elle mérite
kawi600 is offline   Reply With Quote
Old 04-07-2009, 09:33 AM   #5
bakdoor
bakdoor's Avatar
Quote:
I hear ya. Truck is (again) at the dealership right now after blowing one of the lines last week. When I took a look at the plumbing coming out of the MC, it was an easy decision: "Replace them all." What the hell did Dodge use for the tubing on these things originally--looks like rolled up aluminum foil that is now rusted beyond recognition.
__________________
Save the polar ice caps...they taste great in margaritas!
2011 Dodge Ram 2500 CTD-new crawler/toy hauler
2009 Forest River Salem LA 292fkds
2006 Jetta TDI (current planet saver; best tank: 704mi.)
2005 Suzuki Boulevard M50-fuel sipper#2, only faster!
1994 Jeep Wrangler-Rock Crawler
bakdoor is offline   Reply With Quote
Old 04-15-2009, 06:10 PM   #6
Tazman
Tazman's Avatar
vans33rr,
How did you make out?
My line to the rear just blew out tonight. I need the truck so a quick (but done right) fix is important.
How did you route the line to the back? I don't even want to think about dropping that full tank of fuel.....
Cheers,
taz
__________________
98.5 2500 4x4 Auto Short SLT QC.
Edge EZ, 4" SS MBRP Exhaust, K&N air, FASS, isspro pre turbo pyro, boost and mech FP, 1 ton cylinder mod, Yokohama 285/75, Fan what fan? & a DSS to straighten me out. Running B-100 when I can.
My lucky number WAS "53"
Tazman is offline   Reply With Quote
Old 04-15-2009, 07:30 PM   #7
GreatTruck2001
GreatTruck2001's Avatar
Replacing Brake Lines
For those of you that have replaced ALL the brake lines, what kind of time are you talking about? I'm not sure I'm up to the task so I may have to pay my local shop to do the work and would like an idea of cost if I provide the lines from EGR.
__________________
2001.5 Qd Cab 4X Auto, 3.54, Optix Gauges Incl FP, FASS HPFP 95, AFE 75, MBRP S/S 4", HTS UD Trans w/ Suncoast 91% Conv & Mag Hytec Dbl Deep Pan, Quad XZT+, Bilstein Shocks, Mag Hytec Rear Diff, Leer 100LE Cap, KC 517 Bkup Lites, Westin Blk Bars, Warn 9500 Multi-Mt Winch, Michelin LTX AT2 285/75 R16E's, 202,000 Miles
GreatTruck2001 is offline   Reply With Quote
Old 04-16-2009, 07:35 AM   #8
patdaly
Quote:
Originally Posted by Tazman View Post
vans33rr,
Cheers,
taz
Taz, I have always just taped the end of the line ( to keep gunk out while pushing it ) and fed it behind the tank. I clip it front and rear of the tank and have never had issues yet.
No way in earth I am pulling the tank to do a brake line.
__________________
"Brownie"
1997 2500 Ext.cab SLT, 4X4 auto, 3.54 gears, posilock, 98/99 steering conversion. New TC, lovin her again! Sold 3/13/2010, gone but not forgotten.
"Greenie"
1997 2500 Ext. cab SLT, 4X4, NV4500, 3.54 gears, 4" MBRP Exhaust, Ready to install SB DD3250, built just 216 trucks after Brownie!
patdaly is offline   Reply With Quote
Old 04-16-2009, 08:20 AM   #9
Tazman
Tazman's Avatar
Thanks patdaly,
My bro did the same on his '96.
Cheers,
Taz
Old 04-16-2009, 05:36 PM   #10
dkenny
I got my parts at advance auto..just standard stuff..pain to find and right size fitting. I like to justification on that.
I just push from the rear, wigged and twisted until it got through. it took about 1 hour after getting the parts..had to get the darn rusted ones apart
__________________
'99 dodge ram 2500, 4x4, auto. 4" mrbp turbo back, Air Dog 100, fuel pressure, boost and EGT gauges
'06 jeep liberty
'84 Detroit diesel 8.2L turbo..blue bird school bus->no longer. tranny died(4/11)
dkenny is offline   Reply With Quote
Old 04-16-2009, 07:59 PM   #11
Tazman
Tazman's Avatar
dkenny,
Which fitting was hard to find?
Taz
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
