Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > 1st Gen. Ram - All Topics
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 12-10-2010, 06:41 AM   #1
Darrin F.
repair manual
Can anyone tell me where to get a good (detailed) service manual for a 92/93 dodge 2500.
Darrin F. is offline   Reply With Quote
Old 12-10-2010, 06:46 AM   #2
KD93
KD93's Avatar
Ebay.
KD93 is offline   Reply With Quote
Old 12-10-2010, 06:46 AM   #3
dzl_damon
dzl_damon's Avatar
ebay. Factory Service Manual. Don't even waste your time with the Haynes or Chilton stuff. I remember most of their "helpful" chapters were similar to: "Remove the brake calipers. Assembly is the reverse of removal". No pictures most the time, no details.
The FSM can be had in CD (pdf) or book form. Best $50 you'll spend.
EDIT: Search for "93 Ramcharger Service Manual" or whatever year you want on google and check the shopping results. It will be titled D&W 150-350 and Ramcharger Service manual. This is what I have, it includes the diesel engine stuff of course. The book set is $100 but the CD was only $25 or so. Bonus is, the CD can copy the PDF to your hard drive and you can resell the CD if you wanted
Might get deleted, but just helping the fellow out:
http://compare.ebay.com/like/2706526...=263602_304662
__________________
-93 W350, auto, DRW, 210k. Screw lengthened, DDP 45lpm, DennyT II, 366, full gauges, Borgeson, timing 3/16", 4" unique exhaust system, dual batts, maxi fuses, PS I/C, Cooler Tubez, HE351CW, 3/8" lines/4601HP lift pump.
-89 D250, auto, 83k, utility bed, very clean. 2,000hr military IP, 4" exhaust, free mods
-09 Jetta TDi, Malone stage II and DSG tune
-10 Kawasaki KLR650
-83 Kubota B8200
dzl_damon is offline   Reply With Quote
Old 12-10-2010, 07:28 AM   #4
PJ 3
Geno's Garage has them............http://www.genosgarage.com/products.asp?dept=241
PJ 3 is offline   Reply With Quote
Old 12-10-2010, 07:53 AM   #5
Jer12377
Jer12377's Avatar
Location: North Haven,CT "Living in occupied teritory" & Barton,VT
If I remember correctly, the 93 FSM is the only one that has the rebuild info for the 360 GETRAG. Someone correct me if I am wrong?
__________________
1993 W350 5spd Flatbed.... ARP studs, pyro&boost gauges, head temp gauge, Dynamax muffler, Denny T pin, Linkage moved, 366 spring, AMSOIL BHAF, stock air box removed, Dana 80 with an ARB air locker, PS intercooler, HE351CW-custom 3" intake tubes, 4" exhaust pipe, 7x010 Contagious Diesel Injectors in the mail & custom York on-board air in the works......
2002 3500 4x4, auto, 24valve- Dads truck-now with LOTS of mods
Jer12377 is offline   Reply With Quote
Old 12-10-2010, 07:57 AM   #6
dzl_damon
dzl_damon's Avatar
Quote:
It at least has both the 360 Getrag and NV4500 rebuild sections. Maybe that's what you were thinking of? In 93, some of the gas jobs got the NV4500 LD transmission.
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
