#31 |
well i guess no news is good news. i finally put mine on last weekend and all seems well. except now with tight linkage i can really tell my gear box is going south...
__________________
2005 CTD 2500 SLT 4x4 SB, G56. Lorenz 2.25 SAW, Thuren Track Bar, Road Armor front bumper, Dynatrac hub kit, Racor 445R2 fuel filter, MM 12k winch, DSS steering gear brace, Firestone Airbags, Carli upper ball joints, ARE cap, Isspro low press fuel gauge |
#32 |
I got my “AE” steering linkage in. The “AE” is made in Mexico.
At first look you can see that AE has much larger U-bolts for the steering stabilizer bracket than the “AB” part number has. Actually the entire bracket is larger and has flanges on it to keep it from bending. I haven’t had a chance to put it on or see if anything else is obviously different. Any new updates on this recall? I see some discussion on TDR, but I don’t see that anyone has gotten a recall for the parts they purchased.
__________________
2005 SLT CTD, 4x4, G56, SB Con OFE, Gear Vendors OD, Amsoil Bypass, GDP 2-micron fuel filter, Intake horn, & traction bars, 51" Donaldson, Updated steering, dual front shocks, Sometimes Smarty Revo Jr. |
#33 |
This post was copied from TDR this morning. It gives some information that we previously didn't have. H36 is the recall number Chy is using. There is a possiblity that there maybe 2 seperate recalls--one for the vehicles that were repaired under warranty and a seperate one for the parts that were puchased over the counter by walk in customers.
If the "AE" parts are made in Mexico then I think you could assume that they are not covered by the recall unless Powers and Sons(the manufacture of the recalled parts) is located in Mexico. I think they are located in the US. "H36 is on DealerConnect tonight and just as I suspected the service parts are not included. There should (hopefully) be another separate recall that covers it. The production truck recall does say if a 13mm wrench fits the damper bracket it must be replaced. They must have changed the nut size when they figured it out so they can tell good parts from bad. Drag link joint needs to be replaced without inspection. Parts are CBD1H361 for the bracket package and CBFAH362 for the drag link joint package. Parts are currently in stock at several depots."
__________________
2004 1/2 Dodge Quad Cab 3/4 T 4x4, triple pillar mount w/ auto meter gauges, PSM, aFe pro guard 7, Edge Juice, Weston steps, Snug top shell, carpeted bed, Magnaflow muffler, Chrome grill guard, 2 in. front lift, Bilstein shocks and Sirius radio, Ravelco and a Colt Commander anti-theft system. |
#34 |
The "AE" damper bracket nuts for the U-bolts are 15 mm.
#35 |
Yaaaaay - I got the good ones!
__________________
'91.5 W250LE, G360, 4.10, GV OD -366GS, 160gph Pump, 50gal. +Fuel -Onboard Air, Water/Meth, PacBrake, Mag-Hytec -Tach, Boost, Pyro, Fuel Pr, Altfuel, Oil Pr, Trans Temp -34" Dura Grapplers w/17x8 Alcoa Classics, RS9000XLs -Borgenson, Fr&Rear Sway Bars, Skyjacker, Timbrens, Torque Links -GC-01, Fuel Cooler/Racor Filters, Trans Cooler/Filter, Steering Cooler/Filter, Engine Coolant Filter -Ram CAI, Coolertubz, GDS60mm/12cm, Hardened BD Fuel Pin, PSIC, ATS Mnfld, Full Magnaflow 4" Exhaust |
#36 |
Checked online and didnt see that recall for my vin but I am effected by this one ""SAFETY RECALL H34 – DASH SILENCER PAD"".
__________________
2008 2500 HD QC Larime 4x4 Black Crystal Pearl 6.7L 6 speed Auto 4:10 gears Michelins 265/70/R17. 15K Reese 5th Wheel Hitch, Still Stock. United States Army, Retired |
#37 |
i just bought the AE upgrade today and my dealer said the price went up from 3 weeks ago from 250 to 360....im sooooo ****** now..but i bought it anyways and they told me that i had to buy the stablizer upgrade as well...well i politly told them to pack sand on that one...i will be putting an after market one on instead.
#38 |
FYI---The stablizer mounts differently on the new tie rod. You might keep that in mind when looking for something after market.
Jay |
#39 |
carli has a direct bolt on single bilstein 7100 for ~$165...
#40 |
well i got my steering linkage put on and does make a huge differance on how the truck handles....the stablizer shock...i got a manroe shock from checkers for 35.00 and it fits just fine and works great for the pot hole world i live in here....most of them i can avoid...but it makes me look like im driving druck down the road.....lol
#41 |
if you are updating to the new assy 52122362ae you must ck the pn on the pitman arm it stamp on it if is not 68039930aa you must replace it the new one has a diff angle 03 to 07
__________________
work for dodge over 38 yr as tech & parts man 07 6.7 4x4 auto no mods |
#42 |
After reading all the different threads on this subject, i'm a little confused...
It sounds like some people are paying out of pocket to have this recall fixed... am i reading that wrong??... also.... on the post above about the new pitman arm.... is that covered under the recall or will i have to pay to have that replaced too??? sorry for the confusion... i just wanna get my (CENSORED) steering fixed for the LAST TIME and be done with it.... ![]() ![]() Thanks
__________________
-Chris DTR Megacab Club Member #217 06 2500 MegaCab 4x4 SLT Black 6" Lift - King 2.5s / Thuren Towers 37" Toyo MTs / 20x10 Pro Comp Wheels Defiant Steering Brace AFE Stage 2 / Muffler Delete, 5" RBP Tip Some AV Stuff AMP Powersteps On Board Air / Train Horn NightRunner Head Lights DT ProFab Light Bar 3 - 7" H.I.D's |
#43 |
From what I know you are correct, some people are paying for this. It seems if your truck is out of warranty you have to pay for it. The pitnam arm replacement is suggested however I don't think it is a part of the recall. The new pitnam arm has a different angle. Also the new steering stablizer mounts differently on the tie rod so you need to purchase a new stablizer or modify your existing one. My truck was out of warranty so I purchased the new steering kit, pitnam arm and steering stablizer and installed them myself. It's about an hour job if you have a puller for the pitnam arm.(including a beer break)
. I'm sure others will chime in with their experiences and suggestions.Jay |
#44 |
That just doesnt make ANY sense to me..... why are people PAYING to have RECALL work done regardless if they're truck is out of warranty or not?!!?
![]() I just talked to my local dealership about the recall.... She asked for the last 8 of my VIN, and asked how many miles were on my truck (30k Miles) ...put me on hold for a few, came back and said when would you like to bring it in...? My truck's out of warranty, but i'll be damned if i'm paying for something that was recalled...!!... sorry for the rant..... ![]() |
#45 |
I can only relay my experience and what others have told me. If they'll do it for free---go for it!!!!!
Jay |
| Thread Tools | |
| Display Modes | |
