| View Poll Results: if u have a rear end noise what ratio do u have? | |||
| 3.73 |
23 | 71.88% |
| 4.10 |
9 | 28.13% |
| Voters: 32. You may not vote on this poll | |||
Thread Tools | Display Modes |
#1 |
those who have it what ratio do u have and what if anything has been done to fix it?
__________________
2003 Ram 3500 SB SRW HO 48RE 4.10's SOLD 2010 3500 Crew Cad Long Bed Auto On Its Way |
#2 |
Yeah mine just got a whole new set of gears and bearings.. on it went in wed morn.. got it back on friday afternoon.
its quiet now... accept Now it makes the whine noise when you let off the throttle, Instead of when you added throttle...??? i havent put but 20 or so miles on it i figure ill put at least a 100 before taking it back in if it dont shut up... and if you feather the throttle just right where your adding power but sort of coasting in gear it whill make a louder whining noise... before i took it in it was more of a 250,000 mile gear howel yould of expected from a big rig or a wore out chevy. anyways thats my scoop..... btw ive only got 15000 on the clock.
__________________
03 3500 srw SLT Long Bed QC 6SPEED 4x4,5.9HO Mia silencer,Tone ring mod,air box mod,trueflow air filter,exhaust brake,Deflecta shield running boards,billet grill, SOLD2005 Ram 2500 SLT Quad Cab HD,short bed,4x4,Hummin CUMMINS,Auto,White.mia silencer ring,Tru-flowfilter,4" straight,pac-brake,goose neck hitch,Frantz oil cleaner,Tone ring mod,TQLup, Quadzilla towing chip 1958 Mack B Model thermodyne diesel. 3 axle 12 yard Dump truck. |
#3 |
I,ve told them about it twice. Once at about 500mi., and once at about 5000mi. The service manager at my dealership says it is "normal breakin sound". I say #!^*#!!it.
__________________
'05 3/4 SLT. 4spd., 3.73 SB White, Grillz stainless inserts, linex sprayed in liner, Ram hd mudflaps, DSP fifth wheel hitch, Prodigy brake control, Truflo drop in filter, chrome full wheel surrounds, 3M fog protectors, nerf bars, Viper alarm,PIAA Extreme Whites, 40"Nelson, SS Onki Tip, FIA OE Seat Covers |
#4 |
4:10's here
Mine is still brand new and makes the whine noise under "coasting" conditions.
James |
#5 |
I think we can all agree that the new rear ends dodge are using do not stack up to the Dana axles from the previous years.
Rear ends should not make noise until they are worn out, i have yet to see a whine go away after break in. Most of the time it just changes pitch but still remains. new gears that are meshing properly Do Not whine. If dodge saved a few bucks switching suppliers I am sure they are paying for it now big time. I hope they go back to the Dana axles before I am due for a new truck. The shift collar in the front axle or some hubs would be a good idea too. Jason
__________________
Black 2001 quad cab auto with a pile of miles!! |
#6 |
I have an 04 and after reading all the posts here (truck was at 6800 miles) I climbed underneath and checked. Rear end, transfercase, & transmission were all low. So, I changed them all out to synthetics...no gear whine anymore...
__________________
Retired USN CPO! 2004 2500 QC, 4x4, 6spd, HO Cummins, 3.73 anti-slip. Nerf bars, mud flaps, VentVisor, LINEX bedliner, GAGE Brushguard, PIAA Extreme Bulbs, HuskyLiner frt & rear, Mopar Rear wheel liner inserts, Bushwacker Fender Flares, AMSOIL & REDLINE Synthetics, MEG's Exhaust Tip, BFG 31570R17 tires. Truck sold, but not forgotten! |
#7 |
4.10 on mine.
15k miles, no whine.
__________________
2003 2500 QC 4X4 SLT, SWB, Kalifornia SO :( 5spd, 4.10 rear, limited slip, BFG 315/70R17, Line-X bedliner, mud flaps, Superlift Calibrator, Scotty RAM AIR III,... more to come once the wallet fills up again! |
#8 |
F11 Engineer....Nice pics of truck in your photo gallery....
Did you install the 2" leveling kit or just put the 315's on? Have you taken it 4x4 and if so, did you have any mud problems building up in wheel well causing steering problems? thanks |
#9 |
I Got an 03 3.73 rear End Started Howling At 3000 Miles
Told Dealer About it , But I decided to Wait Till Spring To Have it Fixed Hoping Dodge Will Have an Official Fix For It. |
#10 |
I also am going to live with the noise until DC comes up with a real solution. Mine is not that bad and I don't want them to just start throwing ring and pinions at it if it may not be any better than it was before.
__________________
Took delivery 01/11/03: 2003 Ram 3500 Quadcab 4x4, LWB, SRW, HO, Six Speed, 3:73, LSD, Heated seats, Tow pkg, Laramie, Sport, Graphite Metallic, Slate interior, Mopar molded mudguards, Rear wheel well liners, Rhino Liner, 20x8.5 American Racing Chrome Kahunas, 285/55R20 BFG KO-ATs. Just say no to cabmarker lights! |
#11 |
The reason the whine is there is not a design flaw, it is because from the plant some rear ends were set up wrong and the pinion depth is off, and that is why some are on accel and some on decel. The danas were not that much better, you just could not hear the whine cause the motor was so noisy. The noise is just a noise and is not going to damage anything but your opinion of american axles. And no the noise is not a break in noise and will not go away until the pinion depth is fixed.
__________________
I'm A Rebel With A Cause. Southern Born, Southern Bred. I'll Be A Backwoods Badguy 'Till The Day I'm Dead. I Fish, I Hunt, I Chew, And I Drink. I Drive An Old Pickup Truck And I Don't Give A Darn What You Think. I'll Fight For The Right To Keep My Guns. My Flag Will Forever Fly High. 'Cause I'm A Backwoods Badguy...That's Why! |
#12 |
Mine has the 3:73 in. Mine had the noise while partial throttle. Took mine to the dealer and they started that BS about how all the new rear ends make a little noise. I informed them that my 01 dually didn't make that noise. I also informed them that the diffs in big semi trucks don't make that noise. I also informed them that in the early fifties the rear end was perfected enough to not make any noise and that this is fifty years later. i also told them to fix it and rear end noise was not an option I was going to accept. They really weren't going to do anything until I spoke with the general manager. Told him all I said above and he told the service manager to fix it or get a buy back program started. they put in new ring and pinion and zap, the noise is gone
. Also had the vib problem and again I had to force the issue with them to get service. They tried to BS me saying that the new truck frams are stiffer and that why I felt more vibrations. I particularly liked the one about the engineers designed the rear end to make noise and have more vibs. BS I say. Make em fix it or make em buy it back.![]() |
#13 |
I had this problem, new pinion and shaft. She's almost perfect.
I had this exact same issue with my 00 Chevy when they went to hydro forming their frames and put in AAMs. Chevy went over 100k and never had a problem. This truck still vibrates at about 75, I think it's coming from the front end, you can hear it too but had the dealership look at it and ALLEGEDLY it's normal.
__________________
04 2500 QC SB SLT 4X4 373 HO/48RE Graphite/Taupe, Silencer-ring-ectomy, Prodigy, Airaid Filter, ATS: Triple Lock TC, VB, Commander & Deep Pan, Mag-Hy-Tech Diff Cover, Viper 771XV with Remote start, Firestone Air Bags, DiProcal-EGT-Boost-Tranny "Whether you think you can or you can't....you're right" Join your local AZDTR#20 Click here for the DTR membership form, Print it out...fill it out... and PM me for the address to send it in. IT'S FREE!! |
#14 |
I did the fluid change at 15K and now it seems to be quiter. It's still there but no where near as loud as it was. Used Mobil 1 75W-90 Syn.
__________________
Butch K4SM ET1(SW) Retired 03 3500 QC SLT Dually, CTD HO, 48RE, 2WD 3.73LS, Scotty Ram Air III, B/W Turnover Ball with companion 5er and Tekonsa Prodigy Digital controller, Transfer Flow 70 Gal Aux tank, B-D Xmonitor (pryo, boost and tranny temp), Quadzill rail and fuel pressure gauge, B-D Flow Max lift pump 97 Wilderness 30 5X 5er Radios: Kenwood TM-733A and Icom IC-706MKIIG |
#15 |
i feel like a LUCKY one, 19,000 miles, quiet as a mouse
__________________
2003 High output, 48re-4X4, quadcab,SWB, |
| Thread Tools | |
| Display Modes | |
