Sign in using an external account
Thread Tools | Search this Thread | Display Modes |
#16 | ||
#17 |
I had an old Dodge dart with the same symptoms. It would rattle in neutral with the clutch out but not with the clutch in. I figured it was probably either the input bearing or the pilot bearing. I sold the POJ before I had a chance to find out though.
I have read that the crank can be bored out to accept a ball or needle pilot bearing. Can this be done without pulling the engine/crank? Is there a kit for this. The bronze pilot bushing seems to be a weak point. I can see where the t/o would cause extra wear and even damage to the pilot sleeve it rides on but surely the operator would nonice the noise way before this. But then some people will endure the noise until something major breaks, usually at high speed. ![]() Edwin
__________________
1989 D-350 Dually CTD, WH1C turbo Non-IC, boost controller set to 34#, 3200 RPM govenor spring YAY!, Autometer Z-series Tach, Boost and Pyro, 5spd Getrag 360, A/C, Power Steering, Brakes, Windows & Locks. Replaced all seals and o-rings in the VE when I did the govenor spring. Paint sucks but I'm currently stripping/sanding/priming for new paint. See my photo gallery. |
#18 |
On our trucks the pilot bearing is in the flywheel. You just have to remove the flywheel and take it to the machine shop to get it bored for a ball type of pilot bearing.
__________________
Of course it smokes, it's a diesel, Einstein!! |
#19 |
The pilot bearing versus pilot bushing argument has been kicked around on dozens of websites.
I go for the bushing. Reason being, when a roller-bearing gets hot, for whatever reason, it melts the grease out of it; then, it seizes up, spins on the input shaft of the transmission, and really buggers it up, necessitating transmission being tore down to replace the shaft. I have seen bushings in really bad shape, yet do no damage to the transmission. You can drive a long ways with a bad pilot bushing; you will most likely have to call a wrecker with a bad pilot bearing.
__________________
Even in a bone-stock truck, a FUEL-PRESSURE-GAUGE is the first gauge you should install. Splice an in-line fuel-filter AHEAD of the lift-pump and carry a few spares. Blue MOPAR Voltage-Regulator = P3690731 #1 MY TRUCK = 1985 F-350, W/1989 Cummins, 5-sp. Getrag, Dana 70 3:55 #2 HER TRUCK = 1991.5 D-250, LE, I/C Cummins, auto #3 SON'S TRUCK = 1990 W-250, Cummins, 5-sp. Getrag, 3:54 #4 TRUCK = 1991 D-350, LE, Cummins, 5-sp. Getrag, 4:10 |
#20 |
Depends how bad the pilot bushing gets.... I have seen a bad pilot bushing completely destroy an NV4500..... not common, but any wobble in the input shaft is a bad thing for the tranny.
When the clutch starts slipping that can be due to tranny fluid comming out of the input shaft seal and drenching the clutch. You will probably be able to driv it home in that condition but the tranny will already be done for.
__________________
92 Dodge w250. 6" lift, detroit locker. triangulated traction bars, cross over steering, NV4500. forged wheels. 250lb rear bumper. piston lift pump. No Muffler. Big diff cover. 16cm^2 turbo. Rear Disk Brakes. Toyo Open Country M/T's 315/75R-16. 07 MegaCab dually 5.9 6speed 4x4 w/ heated seats, pacbrake exhaust brake, pillar guages, BFG KM2 255's. Off road truck on 44"TSL's, Dana60's 350tbi SM465 dual divorced 205's, 4 driveshafts, and computer controlled air bags all around. |
| Display Modes | |
