Question @P0202 Code
Old 03-11-2010, 12:07 PM
MOAGGIE's Avatar
Ok, so I have a P0202 code...what do I need to do to fix it? I really need some help on this. thanks
Old 03-11-2010, 12:32 PM
Dr.Dizzle's Avatar
I recommend you inspect the injector wiring harness for chaffing and loose connections.
Old 03-11-2010, 12:39 PM
MOAGGIE's Avatar
I wasn't sure if it was something that simple or not. I will check it out,thanks.
Old 03-11-2010, 12:44 PM
Dr.Dizzle's Avatar
Always best to rule out the simple items first.
Old 03-11-2010, 03:40 PM
MOAGGIE's Avatar
Ok checked all the wires, don't see any thing exposed and all connections are tight. Now what do I look for?? thanks for any help.
Old 03-11-2010, 04:05 PM
Dr.Dizzle's Avatar
Since you found no indications of visible damage to the injector harness and plugs externally, then pull the rocker cover and check for anywhere it could be rubbing on metal.
If the wiring is not compromised, I suspect there could be an issue with the number 2 injector, ie;solenoid.
Old 03-11-2010, 07:08 PM
Administrator/Jarhead
madhat's Avatar
You could also pull the injector plugs, clean and apply a small ammout of dielectric (sp?) grease.
Old 03-11-2010, 07:57 PM
MOAGGIE's Avatar
Ok, The check engine light went off just as I got home. so I guess I will check it all over good this weekend. thanks for the help all.
Old 03-11-2010, 10:10 PM
Cummins Guru
BigIron70's Avatar
Location: Sunny Southern California Land of Fruits and Nuts
Disconnect the pigtail nuts from the suspect #2 injector. Using an Ohmmeter, measure the resistance between the solenoid posts of the injector.
NOTE: Be sure to zero the ohm meter prior to checking the injector circuit. The resistance should be less than 1 ohm and greater than 0 ohms if not replace injector.
If the injector resistance is good then replace the valve cover gasket.
Old 03-15-2010, 09:00 AM
MOAGGIE's Avatar
Update
Ok weekend was busier than I planned so I didn't get to do what every one had suggested yet. Truck acted up late sunday afternoon, started running rough, stopped and checked all the connections. started back up and ran fine. got codes P0202 and now a P2146-Bank 1 Shorted-High or Low Cylinder 1-3. So I guess I need to do what was suggested earlier to find the problem. Question is will it hurt anything if I keep running it until I can get time later in the week to check it out or should I try and get it done ASAP?? Don't want to damage anything but work has me running my rearend off this week.
snowmanx
01-13-2012 06:56 AM
browndg
01-17-2011 03:13 PM
EQUIPPRO
11-14-2009 11:07 AM
Terraizer
12-14-2005 03:56 PM
CTD NUT
04-05-2005 04:45 PM
Quick Reply: Question @P0202 Code
