#16 |
connect to obd2?
__________________
03 Black 4x4 2500 SWB Quad Cab NV 5600 Smarty TNT II Silver 62 II CP 3 DDP 50 HP Nozzle SB Clutch con ofe ATS Exhaust Manifold AFE Intake Pro Dry Magnaflow 4" 04.5 Turbo Elbow and Downpipe Aeroturbine XL 4040 GDP Intake Horn/Grid Delete GDP Fuel Pump/Big Line Kit BD Short Shift Di Pricol Gauges Boost,Pyro,Fuel,Rail XD Rockstar 18x9 BF Goodrich AT 285/65/18 JVC Navigation HDD Radio JL Audio Subwoofer and Amp 250 Espar Diesel Fuel Heater Kit Infinty Speakers |
#17 |
if the quadzilla rail gauges connect to OBD 2 or other?
thanks chris |
#18 |
Chris,
it plugs into the injector harness under the hood.
__________________
Daniel My Trucks- 01.5 2500 CTD 2wd 6spd QC/SB Green SLT Loud Audio, Low Fuel Press. Light, 6k Flashtech HIDS 91.5' CTD Sold Dads Trucks- 93' W350 Reg Cab DRW 4x4 CTD 5spd flatbed 4" stack 04' 3500 Reg Cab DRW 4x4 CTD 6spd 87' D150 318 Auto KYDTR#41 Chapter President Contact me on how to join KYDTR #41 Forum So. Ill and In. Welcome Click Here |
#19 |
More specifically, it plugs into the rail pressure sensor with a piggy back harness. The factory plug then connects to the piggy back harness. Hook up a power and ground wire and you're done.
If you opt for the lift pump pressure kit, you install a sending unit at the inlet line to the injection pump using a threaded banjo bolt, and hook up the sender wire that is supplied with the guage harness.
__________________
SOLD 2006 2500 QC SWB 4x4 5.9 CTD, G56, 3.73TR, no mods. I know a little about everything, and a lot about nothing. |
#20 |
Redesign Now Shipping
Hello,
I received my new rail gauge today. Apparently the new design is shipping. Installation instructions look easy, very easy. I have Strep Throat and it's snowing so it will not be installed today. Probably this weekend. Damon
__________________
2006 Flame Red 4x4 2500 Big Horn, 3.73 Gear, 48RE, Goerand VB, Mag-Hytec all around, Quad RP & FP, Line-X, Smarty Jr, PSC Stabilizer, 5 SKS holes done with armor piercing bullets |
#21 |
Hello,
Gauge is in and functioning fine. Thanks Quad. Damon |
#22 |
The one pic doesn't link anywhere....
Could someone post a few pics under the hood and monitor mounting locations? Thanks
__________________
2005 Dodge Ram 2500 CTD 4x4 Quad Cab, SWB Sunroof 2" Leveling Kit 35" Toyo Open Country MT Banks High-Ram® Intake, Techni-Cooler® Intercooler system, Monster® Exhaust Banks Six-Gun® Advanced Tuner, PowerPDA® and Speed-Loader® "My Comments are an ACCQUIRED TASTE.............................. ............................So I suggest you ACCQUIRE SOME TASTE!!!" |
#23 |
how much is the quadzilla rail gauge? i have a 2004.5 ram diesel and would like a gauge for Lift pump pressure and cp3 output/Rail pressure. Does the quad do both? I heard they were breaking down. Are they ok now or garbage? Can you view both pressures at same time or do u have to toggle between the 2?
__________________
RED 2004.5 dodge ram 2500 diesel quad cab short box 4X4,ISSPRO boost/pyro/tranny gauge pod, Chrome Locking Fuel Door, Edge Juice Attitude with Turbo Timer and Hot Unlock mode, Quadzilla RP and LP gauge,Silencer ring removed, Willys Whistler intake,AERO4040XL,Muffler+Cat Delete,AERO 4"-5" exhaust tip,Amsoil Severe gear 75w90 in both diffs,GOEREND triple disc,shift kit,upgraded valve body,FASS 95/150,Bushwacker flares |
#24 |
Hello,
The cost with the LP pressure kit is about 200. You need to switch back and forth between the two readings. It will not display both at the same time. The component that changed and caused the problems has been corrected. My readings consistent. The sensor for the LP must be installed with the provided banjo bolt that has a provision for the sensor right on the cp3. A single wire goes to the LP sensor. The factory rail pressure sensor is used with a piggy back harness as stated earlier. The only other connections are power at the fuse panel under the hood and a ground to the dash frame in the cab. See this thread for a few picts. http://www.dieseltruckresource.com/d...d.php?t=190859 Damon |
#25 |
Will this work on a 2001 Cummins?
I think I ordered this one by mistake. will this work on my trucK? the websites are pretty confusing?
__________________
2001 4x4, 2500, LB, ext cab, 4 wheel disc, tow package HO 24v, bone stock, Keep er' rollin upgrades this month-Quadzillaraider XZT, Recon XZT, FASS Lift pump and Auto-Meter pillar guages |
#26 |
Do you guys know if the on in the DTR store come's with the new sender unit for the fuel pressure.
I read on here that quad said that there won't be any new sender units for fuel pressure besides whats on the shelfs know.
__________________
2005 Dodge Ram 2500 QC Long Bed White, Auto, Muffler missing, Smarty |
#27 |
I took it off of my old truck and just put it on my new truck, but I can't remember which fuse it said to jump off of, anyone know?
__________________
Adam Shopping for a Megacab... 2003 Ram 3500 QC/SB 48re Sold 2003 SO Ram 2500 QC LB 5spd 525hp/996tq 4/14/07 Totaled 12/15/07 |
#28 |
Hello,
I think it was the instrument lighting? Not sure though. I will check tomorrow and let you know. Damon |
#29 |
That's the one that I tapped, I thought that's what I remembered when I pulled it from my old truck. I can't remember what number it was on mine, I wanna say 26, 27 or 28 maybe? lol
#30 |
I run the 4.4 and have the quad, without the piggie back on the sensor my truck was around 370 on the rail, with the piggie back on the sensor i get 875 all on idle. When turbo is at 46 psi i have seen up to 25000 on the rail. Have had a sensor go bad, I think the quad burned it out.
__________________
2005 Ram 6 shooter Smarty 4.4 Beta South Bend DD 3250 AFE Mega Cannon II 4" exhaust IssPro Gauges Puttin out 45 psi boost Quadzilla Rail Gauge 2'' ready lift leveling kit Reacon Marker lights Added on Romik Bull Bar Chrome vent visors 2008 Dyna SCREAMING EAGLE Anniversery addition #469 110 cubic 1975 Trans Am 455 |
| Thread Tools | |
| Display Modes | |
