Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > Performance and Accessories 2nd gen only
Register FAQ DTR Store Members List Mark Forums Read
Thread Tools Display Modes
Old 03-01-2008, 05:32 PM   #31
lostnwalmart
lostnwalmart's Avatar
Send a message via AIM to lostnwalmart
if the apps sensor is not pluged in it should idle and just idle it should not over speed
__________________
2001 4x4,air dog 150, Nadp nv4500, 8 in cat stack, Monster 2VP, south bend 3850, adraline!, custom 6 hole injectors, custom cam, custom p&p head, bd special + a sister?(soon i hope). 105lb beehive valve springs
lostnwalmart is offline   Reply With Quote
Old 03-01-2008, 05:49 PM   #32
pokapotato
Well I felt the same way about it. There is basically no throttle position signal. If anything the truck should not start, or it should just go to low idle. All I know is that when it fired with the engine cold and having sat for a couple weeks it immediately went to full fuel it seemed to me. Scary, and the garage was full of smoke not to mention some disgruntled neighbors who heard a 24 valve Cummins with a straight five inch exhaust go into an overspeed. It's not something you want to try to troubleshoot, but I wonder if it is because of the Adrenaline that it acted that way and because of the tune I had loaded with a very high red line that it acted like this. Can Quad supply any insight?
__________________
2002 Ram 2500 Quad Cab 4X4 short box Red Sport. ATS Trans and 5 Star T/C, Blue Chip Special X VP-44, 275 RV nozzles, Quadzilla Adrenaline (wire tapped utilizing Blue Chip Pump Cover), FASS HPFP 150. 5 inch Expandit exhaust with 6 inch tip, muffler in. Cyberdyne Blue Ice digital engine oil pressure and trans temp gauges, little HY35 with J-hook. Red Top Optimas. Altitude 4300 feet.
pokapotato is offline   Reply With Quote
Old 03-02-2008, 07:11 PM   #33
csrosenberry
Well I switched to a 1000 series production tune. 1025 to be exact. My truck still stumbles at anything over PL02 and gets worse the higher I get. (at or around 1700 rpms). WHY do I have this shuddering? Still have the flashing of the PL even after warmup. And sometimes when I shut the truck off to use the turbo timer I can not kill it with the break or gas pedal the timer just has to run its course to shut the truck down. I am also wondering if any body elses truck runs like mine. When I mash the pedal it doesn't seem like all that much different then stock a little but not much then when I get to 1600rpms wam! there is some serious power and then wam! again at 2075-2150 another strong does of power I like it but I have not experienced the super smoothness of this box with neither 2 production tunes or the aggresive tune that I tried. The power is there for sure but my edge comp was way smoother. It just felt like the truck was more powerful and the adrenaline seems to kick in the power. Any body else's truck seem this way. A quick note to the shuddering If I go to PL00 or PL01 I can not get it to do it and if off the truck works like a charm supper smooth but way less power.
__________________
02' 2500 4x4 6spd HO with 3.55s, 295/75/16 nitto TG 2" leveling kit, 5"FBD exhaust, autometer guages fuel, boost, tranny, pyro. AFE, ADRENALINE, fass 95, w/1/2" lines. South bend DD, DDP4s, ARP head studs, and the BD twins to make her rip.
csrosenberry is offline   Reply With Quote
Old 03-06-2008, 08:17 PM   #34
csrosenberry
Hey quad when you get back can you check this post and my last one on this thread I need some help. I have also found that under light throttle my truck stumbles in the 2000-2300rpm range just like at 1700 but not as jerky sounds more like its missing. I don't know what is the deal DO I get another box, try a different tune, or where do I start to look? I am going to pay attention to the boost guage vs. my mechanical I read something about map sensors where if there bad they throw the adrenaline out of wack. I love the power just want the smoothness I keep hearing about. My truck rips but it has points of added power and stumbling while driving in the above described rpm ranges. Thanks hope to hear from you. If there is a way to get in contact with you on the phone I am sure that I could explain myself much better.
Old 11-06-2009, 06:44 PM   #35
EZuber5
I was thinking about getting the Quadzilla Adrenaline, from hearing all these problems should i still get it?
01 2500 cummins 6sp, 4 inch mbrp, bd stage 1 turbo, k&n intake
EZuber5 is offline   Reply With Quote
Old 11-07-2009, 08:03 AM   #36
x1phats10x
x1phats10x's Avatar
Send a message via ICQ to x1phats10x
these are all old problems the mostly have been solved ive had mine on my truck for over a year now and havent had anyproblems its a great product with many options for power
__________________
2002 47re 4.5 inch straight exhust quadzilla with adrenaline air dog 150 k&n airfilter isspro fuel pressure gauge wastegate blocked off
x1phats10x is offline   Reply With Quote
Old 11-19-2009, 04:07 PM   #37
EZuber5
I just got the Quadzilla Adrenaline today, i put it already and have no problem with it except i cant get my boost to show on the monitor. how do i get it to work? also when i floor the gas pedal it seems to lag, can anyone help me with that?
thanks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.6.7
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2003, DieselTruckResource.Com
