Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > Performance and Accessories 2nd gen only
Register FAQ DTR Store Members List Mark Forums Read
Thread Tools Display Modes
Old 11-20-2009, 08:00 PM   #1
cufd412
Quad vs Smarty
What is the best a Quadzilla ADR or Smarty for a daily driver and hauling don't want to make a lot of power. This is a work truck just want to make a little more power. I need some input. Thanks
cufd412 is offline   Reply With Quote
Old 11-20-2009, 10:25 PM   #2
ellerman
ellerman's Avatar
If you don't already have gauges- I say the Quad.
__________________
2001 4x4 QCLB Sport 6spd HO, Carli arms, Carli Coils, Carli Billet shock towers, 3" Sway-A-Way shocks, Carli 3rd gen track bar, Carli Sway Bar Links, Deaver 12 leaf spring packs, custom made long travel air bags, Defiant dual stabilizer, 3rd gen wheels, 295/70R17 Toyo MT's, Centramatic wheel balancers, Edge Juice with Attitude, FASS, MBRP 4", AFE stage 1, Jammer stage 2 injectors, Jacobs Exhaust Brake, DSS steering stabilizer, Luke's links, Southbend ConOFE, Optima Yellows, Royal Service body
ellerman is offline   Reply With Quote
Old 11-20-2009, 11:17 PM   #3
DIESELWRKS
DIESELWRKS's Avatar
post up what you have on your truck. any mods etc. guages and fuel system need to be dealt with. both products like most boxes or the smarty are great if you have other things to support them. the smarty has great low end power great for towing. but like anything that hits hard on the low end your dealing with smoke. and tranny/clutch depends what you have for aftermarket. on a bone stock truck auto or stick you will have your limits with both products. it really depends on what you want to do with the truck now and still a year from now. if the power bug bites you. tell us what you got and there is alot of good advice out here what ever way you go. but there are some areas that should be addressed with the truck prior to adding power. fuel pressure egt's boost etc. get back to us. good luck
__________________
2002 HO 6-SPD LB 4X4 QC HTT 62/14, SB-DD3600, TST PM3/*REVO-BETA*SMARTY MACH 4'S, RINGED W/ STUDS, AFE/2 " FTE 6" STACK D/PRICOL GAUGES, FASS 150,1/2 DRAW-STRAW, DSS-BOX DT PRO-FAB TRAC BAR, CONV-T STYLE STEERING,DUNKS TRACTION BARS, AIR BAGS,17'' KMC BLACK HOSS, 37" TOYO MT'S 6" LONG ARM LIFT.THANKS RIP@sourceaumotive.
US.MARINE PROUDLY SERVED 1993-2006
DIESELWRKS is offline   Reply With Quote
Old 11-21-2009, 11:13 AM   #4
cufd412
New VP, and a new stock lift pump, installed by Dodge before I bought it.
__________________
Auto, 4X4, K&N FIP kit, 4" exhaust, HY35 going out need an HX35, 225,000 miles and running strong.
Old 11-21-2009, 08:22 PM   #5
JPR Ram
JPR Ram's Avatar
Location: My head lays down in Murrieta, but the day light hours are spent in San Diego, Ca.
Send a message via AIM to JPR Ram Send a message via Yahoo to JPR Ram
You're gonna want to upgrade the lift pump and install a fuel pressure gauge if you do any performance upgrades. Personally, I really like the Quad box for my daily driving and towing.
__________________
2000 4x4, Q/B, L/B, 2" lift, Nitto A/T's on 17x9 Raceline Monster forged wheels, Alpine CVA w/ CD, DVD, XM and I-Pod, RV275's, Quad (beta) XZT+ / Xzillaraider Stack, "Built" 47re w/ Billet goodie's & Dunright V/B, Isspro Pyro/Boost/TrannyTemp/FuelPSI w/ low PSI light, AFE Stage-1, Banks Hi-Ram, Raptor 100 w/ BigLine kit, Straight 4" exhaust with 5" chrome tip, Adj Boost elbow, AND NO turbo silencer
1989 S&S 10' Camper; 1988 Suzuki Samurai; 1986 Honda TRX250R; 2001 Honda XR-50
JPR Ram is offline   Reply With Quote
Old 11-21-2009, 09:22 PM   #6
pokapotato
IMHO You don't need a different turbo for what you want to do. You won't find a turbo that will spool as fast as that HY. You will want gauges, fuel pressure minimum. Factory lift pump will support either a smarty or adrenaline. If after you make the fuel upgrade and you see fuel pressure dropping below 5 psi then think about upgrading. If you are looking for more bang for your buck then maybe an Adrenaline would be good. Either of them are fantastic. I have had both and loved both. Stock trans. probably won't hold up to adrenaline on level 10.
__________________
2002 Ram 2500 Quad Cab 4X4 short box Red Sport. ATS Trans and 5 Star T/C, Blue Chip Special X VP-44, 275 RV nozzles, Quadzilla Adrenaline (wire tapped utilizing Blue Chip Pump Cover), FASS HPFP 150. 5 inch Expandit exhaust with 6 inch tip, muffler in. Cyberdyne Blue Ice digital engine oil pressure and trans temp gauges, little HY35 with J-hook. Red Top Optimas. Altitude 4300 feet.
pokapotato is offline   Reply With Quote
Old 11-21-2009, 09:39 PM   #7
lovinCTD59
lovinCTD59's Avatar
Send a message via Yahoo to lovinCTD59
Chances are you now have the "Intank lift pump" I would get a fuel pressure gauge on that truck ASAP. I could pull down to 0-1 PSI with a STOCK truck.
__________________
01.5 HO 3500 Dually NV5600.
Bosch 300 Injectors-BHAF-ATS
Quadzilla Electronics- PDR HX40 Turbo
Dual 6" Mitre Stacks-Holley Blue
GDP Big Line-Auto Meter Gauges
Cobra-Firestik
205,000 Miles
Factory Clutch
lovinCTD59 is offline   Reply With Quote
Old 11-23-2009, 11:13 AM   #8
cufd412
Thanks for the info.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.6.7
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2003, DieselTruckResource.Com
