Go Back   Dodge Diesel - Diesel Truck Resource Forums > 3rd Generation Ram - Years 2003 and up > 3rd Gen High Performance and Accessories (5.9L Only)
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 03-14-2008, 10:56 PM   #1
White97GTVert
** Quad rail guage came with CCSFPKIT for fuel pressure.. wrong?
Okay so I ordered my Rail Pressure Gauge from XTREMEDIESELPERFORMANCE (XDP). They said the regular fuel pressure senders are discontinued and said they would send one for a commander that will work.
They did. The box says "CCSFPKIT" and below it says 6.0 Ford.
I checked the part #'s on quads site and they seem to be the same. How does this work on the dodge? i don't understand how this will interface with the banjo bolt on the CP3?
Its a bulbous shaped fuel pressure sender and an l shaped thing made up of a bunch of different fittings.
Can I make this work? I am a little annoyed if they sent me the wrong dang part.
Can the fuel pressure module be threaded into the bottom of the filter housing and and not worry about the banjo bolt issue. Or can someone please explain how I would make it work with the CP3 banjo fitting.
Unfortunately I can't get you all a picture at the moment.
Is this a universal kit (CCSFPKIT)
Thanks! Quad please help!
__________________
'05 2500 QC 4x4 - Cummins Power Baby! - Smarty b4.2 - AFE Intake - 5" Turbo back Exhaust - HTS Full Billet 48re - PPE Dual Fueler - A little pressure from the EZ - Airdog 150 - HTT 64/71/13ss - F1 Springs - Flux 3's --- I need more Turbo.. -- BD Exhaust Brake + Towloc -
'05 2500 QC 4x4 - Smarty TNT - AFE Intake - 4" Turbo back - HTS Full Billet trans - Floor It stage 3 pump, Flux 2's - F1 Springs - ARP Studs - RP 150 + GDP 2mk Filters - Small twins 62/3b - BD Exhaust Brake + Towloc - Tow rig
White97GTVert is offline   Reply With Quote
Old 03-14-2008, 10:58 PM   #2
Cummins610
Cummins610's Avatar
Should of got it from larry.....Quad FP kit is a nice piece
__________________
2001 24v - Comp Box
2005 CR -
Cummins610 is offline   Reply With Quote
Old 03-14-2008, 11:07 PM   #3
White97GTVert
Despite where I got it (somewhere that took my AMEX)
Do you have any input on the CCSFPKIT model? It is also listed under Dodge parts on the Quadzilla site. I just don't see the banjo fittings.
Can I screw the sender directly into the bottom of the fuel filter housing instead of going int he CP3? Will that work?
Any help appreciated.
Thanks!
Old 03-14-2008, 11:20 PM   #4
53 willys
53 willys's Avatar
If I am understanding this right all you need is this.......Click the image to open in full size.Right???
__________________
I Drive Diesel's.......
53 willys is offline   Reply With Quote
Old 03-14-2008, 11:28 PM   #5
White97GTVert
Quote:
Mark you are probably right. Where can I get on of those.. Like tonight or tomorrow. I am installing all this stuff tomorrow and want to make sure I get it all done the same day.
Any ideas (farm shops, dealership, etc)
Thanks!
Old 03-14-2008, 11:34 PM   #6
53 willys
53 willys's Avatar
Thanks!
I could get you one...but no way I could do it by tomorrow....is there any diesel performance shops by you??? isn't Rip source up there in WA??I don't think those banjos are something a local parts store would carry....somebody up there must have one...it might be hard on a Saturday tho....sorry I guess I am not much help
Old 03-14-2008, 11:36 PM   #7
White97GTVert
Rip is down south about 160 miles from here. Bit of a drive. I guess its not THAT important (to drive 320 miles to get one). . I thought I read somewhere there is a fitting this could thread into on the bottom of the filter assembly on the engine.
I'll have to keep searching.
Thanks for the ideas though!
Old 03-14-2008, 11:42 PM   #8
53 willys
53 willys's Avatar
if you have the tools you could maybe tap your stock bolt to get you by???
Old 03-14-2008, 11:45 PM   #9
White97GTVert
Tap my own bolt...
Yes I supposed that is an option. I have the drill press but not sure if I have the tap/die. I'll have to look.
Do you know anything about the fitting on the bottom of the factory fuel filter housing? Is it a banjo as well?
Old 03-14-2008, 11:47 PM   #10
tristan21
tristan21's Avatar
Check for a hyspeco or parker high preassure hose store close buy. You can get it from about anybody that deals in hydrolic repair hoses and parts.
__________________
2004.5 SB, quad, 4x4, 6spd, Aurora 5k, SMARTY TNT (PG-13), MP8, TST ra49, FASS 150, flux 3.3, floor it stg3, studs, Banks CAC, Xtreme MT 35's, 6" stainless stack, BD Shorty, Magnaflow, commander, SBC DD #3850, K&N, 83,000 miles
"I'm doin alright for country trash...."Johnny Cash
1st Dyno run on #2 634hp/1323tq no MP-8 or TST:(
tristan21 is offline   Reply With Quote
Old 03-15-2008, 12:24 AM   #11
53 willys
53 willys's Avatar
my stock fuel filter housing had banjos on it as well....inlet and outlet are banjos...
Old 03-15-2008, 07:09 AM   #12
sallyman1
sallyman1's Avatar
i just ordered a quad rail gauge and LP kit from the DTR store? will i get same results? will i get a good one updated one? is the store on this site good?
__________________
RED 2004.5 dodge ram 2500 diesel quad cab short box 4X4,ISSPRO boost/pyro/tranny gauge pod, Chrome Locking Fuel Door, Edge Juice Attitude with Turbo Timer and Hot Unlock mode, Quadzilla RP and LP gauge,Silencer ring removed, Willys Whistler intake,AERO4040XL,Muffler+Cat Delete,AERO 4"-5" exhaust tip,Amsoil Severe gear 75w90 in both diffs,GOEREND triple disc,shift kit,upgraded valve body,FASS 95/150,Bushwacker flares
sallyman1 is offline   Reply With Quote
Old 03-15-2008, 02:14 PM   #13
White97GTVert
Quote:
No I'm sure you will get the right parts. It was a mistake on XDP's part. No worries for you!
Old 03-15-2008, 07:46 PM   #14
mattf
mattf's Avatar
dynomite diesel is in monroe, that isn't more than an hour or so is it?
__________________
2007 QCSB 4x4 6.7, Smarty, straight pipe, EGR delete, 35" Nitto Trail Grapplers (sweet)
mattf is offline   Reply With Quote
Old 03-16-2008, 12:20 AM   #15
lesimon
Just to let you know that if you drill and tap the stock banjo bolt that it will not be be very strong I looked at that option. I ended up purchasing a banjo bolt from a Dodge dealer and welded on a 1/8 hydraulic threaded coupler, worked great and is strong. I did the same thing for the boost bolt. I was unable to find anyone in British Columbia, Canada that could supply these bolts/fittings. Good luck with your install.
lesimon is offline   Reply With Quote
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
