Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > Performance and Accessories 2nd gen only
Register FAQ DTR Store Members List Mark Forums Read
Thread Tools Display Modes
Old 02-13-2008, 12:29 PM   #991
blondeguy08
what is a bad number for egts? im hitting about 1800 with the egt protection off...... if i use the setting with it at 1250 then i lose ALOT of power....
blondeguy08 is offline   Reply With Quote
Old 02-13-2008, 12:38 PM   #992
xtoyz17
Send a message via AIM to xtoyz17
Quote:
1300* is about the max safe limit. 1800* is asking for trouble, as in you're lucky you didn't melt a piston kinda trouble.
__________________
SOLD 06' QC/SB Auto Laramie.
SOLD 99' QC/SB Auto Sport.
SOLD 96' 2500 Reg Cab
xtoyz17 is offline   Reply With Quote
Old 02-13-2008, 12:39 PM   #993
blondeguy08
dang....... because i really really liked the power......
Old 02-13-2008, 12:41 PM   #994
blondeguy08
i hit 1200 almost instantaneously.
Old 02-13-2008, 12:45 PM   #995
dodgediesel
dodgediesel's Avatar
You'll loose a bunch more power if you keep going to 1800 on your EGT's!!! A new motor is around $8000-10,000, now that's a big loss all together!!! On the serious side, you shouldn't hold your motor at more than 1250 for a long period. Short bursts to 1500 is ok as long as it's "short bursts" or you will cook a piston. My engine costed me $10,000 over a race with a Duramax. I held mine at 1500 for approx 1 minute and did extensive damage to the tune of $10,000. on my part!!!
__________________
2007 Laramie 5.9 4x4 SB Auto
6" BDS Long Arm
BDS Traction Bars
20" XD Badlands
37"/12.50/20 BFG AT KO's
Smarty REVO TNT POD
Floor It DIY CP3 Kit
TS MP8
FASS 95/150
AFE Stage 2
MBRP Dual 4"
AFE Bladerunner
Fluidampr
DTT Shift Enhancer
DSS Steering Stabilizer
Mag-Hytec Front & Rear Diff Cover, DD Tranny Pan
Quadzilla Commander W/Fuel Pressure Kit
Quadzilla Boost Fooler
Excell Full Billet 48RE
dodgediesel is offline   Reply With Quote
Old 02-13-2008, 12:46 PM   #996
1-5-3-6-2-4
1-5-3-6-2-4's Avatar
are you on a stock turbo? ..........that'd be the problem right there
__________________
Luke
'97 Chevy V3500 CC DRW 6BT 22" Alcoas
'98.5 24v 2500 QC 5spd 4wd Demon hot-rod *sold*
'90 VW Jetta 1.6L oilbrnr 5spd coupe wolfsburg
'73 RS/Z-28 Survivor.
1-5-3-6-2-4 is offline   Reply With Quote
Old 02-13-2008, 12:54 PM   #997
blondeguy08
yes im on a stock turbo and yes i only hit those hight temperatures in burst.
Old 02-13-2008, 12:57 PM   #998
xtoyz17
1800* is too much, period. Best thing you can do is more boost or a bigger snail. Otherwise, sticking with defueling is your best bet.
Old 02-13-2008, 01:01 PM   #999
blondeguy08
ok.... well im a computer programmer and i may modify the defueling on it to allow me to hit 1300*
Old 02-13-2008, 01:05 PM   #1000
xtoyz17
Email quad, he can make a file for you (if he has the free time to begin with).
Old 02-13-2008, 01:07 PM   #1001
RowJ
RowJ's Avatar
You're Ok to 1600* for 8-10 sec. Drag racers do it all the time. If third gen, even higher. (fill in signature, please).
RJ
__________________
02, 2500, QCLB, 4x4, Auto, 3.55 Power-Lok LSD - DTT/Billet - Smarty/Pulsed Adrenaline - Mach 6's - BD Twins - Snow's H2O/Meth - FASS - F-1 Cam/Valve Springs - HTT Manifold - LazarSmith Bars - TC Lockup Switch - RAD - 3rd Gen Brakes - Fluidampr - DSS - 315/70/17 Pro Comp Xtreme A/T's
Best Dyno - 628 HP/1266 ft-Lbs.
Best 1/4 Mile - 12.72/105.94 - (7460 lbs)
RowJ is offline   Reply With Quote
Old 02-13-2008, 01:08 PM   #1002
Tiger Rag
Tiger Rag's Avatar
how do you identify turbo surging? i love mine except it wont let me switch from pl00 for like 5 mins after running..... whats that about? warm up time?
Headgasket friendly feature!
__________________
2001.5 2500 QC LWB, 6 spd, HO, 3.55's
*TST Comp, Smarty, M6's, BD Twins & Thuren TB by McMopar, BD Short Shifter, Fluidampr, TRE DIESEL performance head - ported, o-ringed, studs & F1 valve springs. SBC 3850 SHDD, II HRVP, & F1 Helix 2 - 12v lift pump by Timinva, 2" leveling kit, Bilstein 5100's, 35" OpenCounty M/T's, DSS,
*Best Dyno: 2/17/07 Carolina Auto Masters, Durham, NC:
Corrected 590 HP 1144 TQ
Uncorrected 615 HP 1192
Tiger Rag is offline   Reply With Quote
Old 02-13-2008, 01:12 PM   #1003
blondeguy08
okay..... well i love the adrenaline.
Old 02-13-2008, 01:15 PM   #1004
qzilla
DTR Advertiser
Put a charger on that thing. You have no idea how much power you are missing out on right now.
You are also going to need a clutch, you are not putting anywhere near the potential of the box to the ground on a stock clutch and a stock charger.
qzilla is offline   Reply With Quote
Old 02-13-2008, 01:20 PM   #1005
blondeguy08
btw updated sig.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.6.7
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2003, DieselTruckResource.Com
