Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > 12 Valve Engine and Drivetrain
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 04-09-2007, 08:38 PM   #1
bigblockdart
A pulling question??
I have a 97 dodge 2500 4x4 auto diesel and when I pulling my inclosed trailer with a head wind and going up a hill not a real steap going about 70 mph running about 2 grand coming up to the hill I will start loseing speed and rpm I check my mirror I don't see a lot of black smoke and I really don't hear the turbo spooling up it pulls good off the line but when crusen down the road like I said befor it loses power it some times dosen't have to be windy for this to happen but when it is windy it happens more often, I have read the other post about the fuel plate and star wheel then I read something about the t/c lock up switch, to me the trans dose shifts in to lockup to fast like in 5 mph from shifting in to overdrive, and this truck is bone stock be sides the turbo I had to replace a couple years ago and the truck has over 280,000 miles and still have the orginal trans it never been rebilt and thats not a b/s statement when I'd work at the local chrysler dealer we serviced that truck since it was new and I'm working on a bugit because all my money goes to the money pit in my grage like my name says big block dart, any input will greatly be welcomed
thanks
bigblockdart is offline   Reply With Quote
Old 04-09-2007, 09:21 PM   #2
dieselfuelonly
DTR question asker
dieselfuelonly's Avatar
Well you said the turbo had to be replaced, is it the stock turbo or did you replace it with something bigger/smaller?
Anyway, good place to start is here:
When was the last time you changed your fuel filter? Did you recently switch to bio? Your filter may be clogged up and robbing you of power. How about the air filter?
Does the engine seem to "lug" when going up the hills?
Hopefully the answers to some of those questions will get you a start here.
P.S. Welcome to the site!
__________________
Hi my name is Dennis.
My YouTube | KDP Tabbing Pics
1996 Ram 3500 2WD | NV4500 5Spd Swap | ISSPRO Boost + Pyro | 6" Side Dump | KDP [S]tabbed to Death | #10 Plate | BHAF | SBC MU0090 | No Silencer | Goodyear 235/85
Last edited by dieselfuelonly; 04-09-2007 at 09:22 PM.. Reason: turbo can be bigger OR SMALLER :)
dieselfuelonly is offline   Reply With Quote
Old 04-09-2007, 10:12 PM   #3
bigblockdart
turbo is a stock replacement- I wouldn't say lug when going up hill its like something is cutting off the fuel, I will have it floored it dosen't matter until it get down to about 55 and down shifts holds at 60 out of overdriver, and I serviced the truck not to long ago so all the filters have been changed and they don't offer bio fuel here yet in kansas. hope this helps with some more Ideas
Old 04-10-2007, 12:36 AM   #4
cumminsdriver635
cumminsdriver635's Avatar
Well, its understandable to lose a little speed. Your truck is only rated 180hp stock, so its not gonna be a screamin demon. You shouldnt see any smoke if the truck is stock. You could problem fix your problem by sliding the fuel plate forward. It would give you a little more pep, and should hold speed better.
Eric
__________________
Mine: 94 2500 4x4 12 valve 200k+miles
3:55 LSD Dana 80
337hp/772tq before turbo
Fuel:#0 Plate, 4K GSK, 191 DV's, 215 Injectors, 16* timing
Air: HX40/16
Tranny: Stock 47rh w/ Built Goerend VB and Triple Disc Converter, billet apply lever, Suncoast flexplate, billet input and a lockup switch
Other Stuff: 4in to 6in bull hauler, EV Isspro gauges,16x8 Eagle 058's
Awaiting installation:New Era 370's
Dads: Stock 98 4x4 12 valve 5 speed.
Single Stack Club Member #4
cumminsdriver635 is offline   Reply With Quote
Old 04-10-2007, 07:49 AM   #5
dieselfuelonly
DTR question asker
I would still look into getting some gauges before you slide the plate at all especially since you are towing in hills.
Old 04-11-2007, 12:50 AM   #6
Redneck_King
Aren't the 1997's rated for 215 hp stock? Just a thought.
__________________
1997 Dodge 2500
Current Mods:
Cat and Muffler MIA
AFE Stage II Cold Air
Custom #100ish fuel plate
Plate and AFC slid all the way forward
Starwheel cranked almost all the way forward
Silencer Ring is in glove box
Straight 3 inch exhaust
33 inch pro comp mts tires
Coming Soon:
Tuff Country 5 inch lift kit
Bigger Turbo
Redneck_King is offline   Reply With Quote
Old 04-11-2007, 12:57 AM   #7
cumminsdriver635
The stick shifts are, not the auto's though
it goes like this:
94-95 automatics 160hp
94-95 sticks 175hp
96-98 automatics 180hp
96-98 sticks 215hp
Thats excluding the California emission trucks though
Eric
Old 04-12-2007, 05:46 PM   #8
bigblockdart
hey thanks for the help guys
Old 04-12-2007, 06:20 PM   #9
Sleigher
Sleigher's Avatar
Kinda Normal
Sounds kinda normal to me.
I've had mine since new and that is basically how it runs. The one thing that I did, long before I put in a new plate, was changed the exhaust and air filter. I put in one of Banks stage one kits (I think) it was a long time ago. The one with a bigger mandrel bent cat-back exhaust and a new K and N filter.
Where I saw the most difference was on grades. It seemed that the truck breathed better (which is why I did that stuff) and consequently pulled hills better. I have a gear splitter on my truck and after the mods I was able to climp hills with overdrive split, whereas before I had to take out the splitter and run in regular fifth- I have a manual.
That's all I have to say about that.
P
__________________
1994 4X4, Manual, 4" exhaust, K&N air filter, changed plate, played with spring, 300 horses on the dyno.
Sleigher is offline   Reply With Quote
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
