Thread Tools | Search this Thread | Display Modes |
#1 | ||
Programer and batteries?
__________________
98.5 2500, NV4500 w/ cast iron extension housing, FASS DDRP, AFE 4" turbo back, 3rd gen rims w/ 265/70r17 hancook dynapro atm rubber, hypertech maxenergy programer. Last edited by cody_d; 12-06-2010 at 11:58 AM.. Reason: Added signiture |
#2 |
No,
Removing the battery cables will not erase the tuning. GW |
#3 |
Cool, then I'll reset my APPS then. Thanks
#4 |
? I do know that with a smarty it is recommended to take the software off if you unhook batteries so I dont know how much diff your tuner is. IMO I would put it back to stock. it dosn't take long and atleast you would know for sure there is not going to be problems
__________________
2002 6-SPD LB 4X4 QC BD 64/71/14, SB-DD3600, TST PM3/SMARTY MACH 4'S, RINGED W/ STUDS,HAMILTON BIG STICK,SPRINGS AFE/2 " 5" EXH D/PRICOL GAUGES, FASS 150, FUEL-STRAW, BORG BOX AND SHAFT, DSS-BOX DT PRO-FAB TRAC BAR, 3RD GEN UPGADED STEERING,DUNKS TRACTION BARS, AIR BAGS,17'' KMC'S, 37" TOYO MT'S 6" LONG ARM LIFT.THANKS RIP@sourceaumotive. US.MARINE PROUDLY SERVED 1993-2006 -NO BETTER FRIEND NO BETTER ENEMY- |
#5 |
I was thinking might need to take the program off, but I'm sure it's not real good to reprogram the computer to many times. What oppinions do you all have?
#6 |
I certainly don't know anything about ECM programming, but it would seem to me that it wouldn't make a difference what you have the ECM flashed with--you should be able to disconnect the batteries all you like without harm.
Whether stock software is stored in the ECM or aftermarket, the effects of disconnecting and reconnecting the batteries is the same. |
#7 |
its simply cheap insurance to return it to stock and takes 5 minutes. It is not going to harm the ECM to reprogram the computer 1000 times. all it is is data transfer and the data can not be lost as there is no way for it to get a virus or anywhere for it to go.
#8 |
You have a very good point, I didn't think of it that way.
| Display Modes | |
