Thread Tools | Search this Thread | Display Modes |
#1 | ||
Problems Fixed on 2002's: Lift Pump, Trannys, etc.
__________________
2002 Ram 2500, SLT, Patriot Blue/Grey, Quadcab, 4X4, shortbed, auto, Trailer Tow group, Camper special, 3.55 gears Anti-spin differential, ATP Wrap, Soft Tonneau cover, Auto-Vent Shade bug shield. Delivered 6-24-02. |
#2 |
Re:Problems Fixed on 2002's: Lift Pump, Trannys, etc.
Umm my truck was bombed from the day I got it I dunno much about any issues I lost my warranty the day I drove my truck off the lot. As for probs, un just the balljoints in the front end of mine are worn out already. Other then that any probs I have had are a result of bombs. I do have a good lift pump though and my tranny is holding for now with a TQ and VB upgrade along with better clutches. Hope this helps<br>Jamie
__________________
02 Ram,Scotty II,Edge comp,Edm's,B1KS,4",DTT trans,Full Air ride,Airbrushed,Eagle Rims,ARE Tonneau,Bremen Boards,Sir Micales Roll Pan,Diamond Clear Tails,Clear Cab lights, Clear Corners,Bed Rug,Onboard Air,Aline CVA1005,JL Componements. 05 Duramax Edge Box,ARE Intake,4" exhaust 95 Eagle Talon TSi AWD. Lots stuff Runs 12's |
#3 |
[quote author=Jones0027 link=board=4;threadid=10151;start=0#96956 date=1043677489]<br>Diesel Gods,<br> Have alot of the past problems with lift pumps and tranny's been fixed on the 2002's? <br> <br>[/quote]<br><br>Well you have the latest and greatest lift pump. Should last longer if you don't bomb, if you don't drive WOT and then get off the pedal and if you keep it over 1/2 full of fuel at all times. Plus use a good diesel fuel additive that lubes the system. As for the transmission it is one of the best going per some transmission experts I have spoken with. It will last a long time if you don't bomb your truck or abuse it by towing or pulling loads outside spec's, and change the fluids and filter per the owners manual.
__________________
3500 4x4 ETH/DEE (02) |
#4 |
I have had a lift pump fail on my '02.<br><br>
<br><br>Dave
__________________
'02 2500 SLT CTD, Auto, 3.54, 285 Cam with 12V lift pump, big sticks, twins, DTT trans, o-ringed and studded head, 3rd gen alloy wheels Stocky |
#5 |
I have a friend who pulls Hot shot and has 2 02 with over 100k<br>on them and have never had a problem. I will soon be buying one of these trucks so if anything goes wrong I will be sure to tell ya.<br>DM01
__________________
Aaron [color=blue 94 Dodge Cummins Diesel forest green 4x4 reg. cab (2002) 5spd 215 pumped set at 30* 5x16 edm injectors ported,polished, and O-ringed head with custom valves and springs snow water meth kit put to the ground by SBC DD clutch[/color] twins soon 04 auto commonrail (stock)01 p-pumped 24v 6spd 98 dodge CTD 93 dodge ctd 95 dodge gasser Its a Horse power thing Ford owners wouldn't understaind Thanks Peter of South Bend Clutch for the new tranny clutch and help |
#6 |
There have been '02's with lift pump problems already.
Supposedly it is a newer design. Maybe these failures are early production 2002's using up the last of the older lift pumps? Kind of like the KDP in the early 98.5's and 99's, using up the last of the older style gear covers? Mine has been fine so far, only had it on a Briarhopper gauge once though, and that was idling and a little pedal, not WOT. My transmission is still fine as well, but I am unBOMBed so far. phox
__________________
2002.5 Dodge Ram 2500 4X4 SOLD 2009 Jeep Wrangler Unlimited X 4x4. Detonator Yellow in color Bone stock for now, at least for a couple months 2008 Harley Davidson FLHR Road King. Black Pearl in color 12 inch apes, stainless cables, Vance & Hines pipes, garage door opener, combo speedo/tach |
#7 |
My transmission is still fine as well, but I am unBOMBed so far.<br><br>Sounds like you are on your way though Phox!<br><br> ;D<br><br>Dave
#8 |
Soon I hope.<br><br>phox
#9 |
One lift pump, one set of transmission electronics, current TC, replaced my semi-ok lift pump with Holley Black.
| Display Modes | |
