-   12 Valve Engine and Drivetrain (https://www.dieseltruckresource.com/forums/12-valve-engine-drivetrain-100/)
-   -   Lost 5th gear....what now? (https://www.dieseltruckresource.com/forums/12-valve-engine-drivetrain-100/lost-5th-gear-what-now-98989/)
12valve2nv Apr 9, 2006 10:45 AM
So last night I am driving home from a friends house and I lost 5th gear in my NV4500. I read somewhere there is an easy fix...anyone have any info they can point me to? Thanks
Partsman Apr 9, 2006 11:46 AM
See the post in the "help" forum.
John Faughn Apr 9, 2006 01:22 PM
Do a search here using the term , 5th gear nut , one of the weak points of these trucks , you should find an upgrade fix for the problum , not simple but also not a real big problum , especaly if your truck is a 2x4 .
jaconst Apr 9, 2006 04:09 PM
http://dodgeram.info/tsb/1998/21-10-98a_r.htm
heres the link to the tsb
hope that helps also someone in help section has been helped with same problem also if you leave tranny in remember its important to use 12 point socket on tail shaft housing bolts don't want to strip them like I did.
GOOD LUCK
12valve2nv Apr 10, 2006 09:32 AM
Well, from what I have seen it looks like the quickest and easiest fix is to get the updated shaft and fifth gear from Standard trans. Has anyone here done this upgrade? How long does it take and how hard is it?
NMCTD Apr 10, 2006 11:49 AM
These guy has several 5th gear fixes also, and is excellent to deal with
http://www.quad4x4.com/index.html
