-   24 Valve Engine and Drivetrain (https://www.dieseltruckresource.com/forums/24-valve-engine-drivetrain-89/)
-   -   best 5th gear fix nv 4500 (https://www.dieseltruckresource.com/forums/24-valve-engine-drivetrain-89/best-5th-gear-fix-nv-4500-a-95203/)
zip Mar 9, 2006 07:32 PM
Does any one know the best fix for the 5th gear to keeping it from backing off the spline on the mainshaft of a NV4500.I hear that the torque king is the way to go I just need to get it wright the first time.I tow heavy loads so I need all the insurance I can get.Any one had any experance with the torque king .THKS. ZIP
texaspower19 Mar 9, 2006 07:37 PM
A guy at home with a transmision shop told me he got pieces made at a machine sop and welded em on to keep it from moving. Dont know mutch about what he told me.
Yukon Dodge Mar 9, 2006 10:09 PM
I've studied Quad 4X4's website extensively, and talked to them several times on the phone, so that is what my experience is based on. My truck was too old with too many miles on it to justify more than having the replacement aftermarket fifth gear fix, which has a new type of retaining system. If you weld it, and it breaks, it will likely ruin the rest of the gears while the pieces go through it. If money is no object, and you want durability, then spring for their $4K tranny, which is a NEW tranny that they have updated with the Torque King shaft and gear...IMHO.
Dr. Evil Mar 9, 2006 10:52 PM
The best fix, I believe is the fully splined shaft:
http://quad4x4.com/Dodge%2094-04%20NV4500.htm
http://www.standardtransmission.com/
zip Mar 10, 2006 11:17 AM
Yukon what did you end up doing to your transmission ZIP
Yukon Dodge Mar 10, 2006 12:00 PM
I found a guy in South Carolina that does nothing but gear work, and had him go through it. The fakalou needle bearing that had been replaced with the clutch failed after 12K miles, and ruined the bearing surface of the input shaft. So along with replacing that, he replaced the output shaft with an "aftermarket" shaft, which has a fully splined support for the gear, as Dr. Evil mentioned. I really had to weigh affordability with durability here, since I was 5,000 miles from home with my trailer; I would have much rather had Quad's Torque King, but I think I know how to drive this thing, and never lug it in 5th. As soon as I can shift down, I do so. He also replaced all the bearings, seals, synchros, etc. Hope that helps!
Copenhagenjunkie Mar 10, 2006 12:59 PM
I believe the best fix is swapping to the 5600. My 5th gear failed @ 120k and I did the swap and never looked back.
Yukon Dodge Mar 10, 2006 01:20 PM
That's interesting...I've never researched that out, but if this tranny fails again, perhaps I will, since it is possible to do a swap like that. Thanks for the info!
zip Mar 10, 2006 09:32 PM
Thanks yukon I will keep that in mind.Do you know any one that has put in one of A.T.S.diesels HD Trannys they are $2400.00 exchange
Yukon Dodge Mar 10, 2006 10:40 PM
No, I sure don't...and you're very welcome!
zip Mar 11, 2006 10:07 PM
Copenhagen what did your 6 speed run you installed and did it involve much modifacations . Also where did you have it done THKS ZIP
Truckman Mar 12, 2006 03:51 PM
Not Enough Horsepower
I must not have enough Horsepower cause I did The Dodge Fix 60000 Miles ago and have not had a problem yet...Plus Truck is all Stock,, 5th Gear fix cost me $75.00 What a deal, Cheapest thing to fix on the truck yet!!!!
