-   3rd Gen High Performance and Accessories (5.9L Only) (https://www.dieseltruckresource.com/forums/3rd-gen-high-performance-accessories-5-9l-only-107/)
-   -   wiring for a winch (https://www.dieseltruckresource.com/forums/3rd-gen-high-performance-accessories-5-9l-only-107/wiring-winch-87681/)
mitchkim Jan 2, 2006 06:44 PM
wiring for a winch
can i use the 12 volts that come out of the trailer plug to power my winch
i have the trailer end that i will hook to my winch and only run power and a ground out of
my winch has a 50 amp breaker on it
will this much power overheat the trailer wiring harness
phox_mulder Jan 2, 2006 06:54 PM
Yes, that wiring was made for lighting and not much more.
Look at the size of the winch cables compared to the size of the trailer wiring.
phox
03 ant a hemi Jan 2, 2006 06:54 PM
Do not use the trailor wiring harness. Run a seperate power and ground wire to the back of your truck. Use #2 wire. Cheers good luck.
Bad Ramer Jamer Jan 2, 2006 07:22 PM
I have a wiring kit made by Superwinch. It elimanate's the need for a battery for the winch. You can get it from Summit. However, all's it is is #2 welding cable. I found a local battery supply place that sold all the connector's and wire for a fraction of the price.
http://www.superwinch.com/pages/access.html
