-   24 Valve Engine and Drivetrain (https://www.dieseltruckresource.com/forums/24-valve-engine-drivetrain-89/)
-   -   Venting - stupid fuel lines (https://www.dieseltruckresource.com/forums/24-valve-engine-drivetrain-89/venting-stupid-fuel-lines-82497/)
darrenG Nov 8, 2005 09:41 PM
So, after fixing the hard start problem, I thought I was golden. Recently, hard to start again, cylinder 6 was leaking, bad. Went to replace that, took all the lines off, didn't keep them in sets of 3, and now I can't get cylinders 1, 2 and 4 back on correctly. 3, 5 and 6 are on fine, it seems. I spent 6 hours working on this, I've done it before in 1.5 to 2 hours, replacing the 6 lines. I don't know what's going on, I just can't get cylinders 1, 2 and 4 to be happy together. [verymad]
so irritated! I can't find any pictures of the lines, anywhere, either.
RCW Nov 8, 2005 10:47 PM
You need to get your hands on Section 4B of Haynes Repair Manual #30041. There is a picture, the routing instructions, and the torque values. The entire manual is around $15 at most autoparts stores.
