-   24 Valve Engine and Drivetrain (https://www.dieseltruckresource.com/forums/24-valve-engine-drivetrain-89/)
-   -   Water Pump/Fan help needed. (https://www.dieseltruckresource.com/forums/24-valve-engine-drivetrain-89/water-pump-fan-help-needed-81818/)
fourwhls00 Oct 31, 2005 10:54 AM
I really just want a confirmation on what I think is going on.
After investigating extra noise coming from the front of my engine, I have found a significant amount of play coming from the area where the fan pulley mounts to the water pump.
Basically, when I grab the fan blades and twist the fan back and forth in a direction that is perpendicular to the rotational axis, the fan pulley rocks about 3/8th of an inch.
I am assuming I have a worn bearing or surface somewhere, but I really can't tell where till I tear it apart.
My best guess is that the water pump in on the way out the door, but are there other possibilities?
I really want to go tear it apart right now, but the whole 8-5 work thing is getting in the way, so I guess I am desk analyzing the situation.
What do you think?
infidel Oct 31, 2005 07:57 PM
The water pump isn't behind the fan, it's over towards the passenger side.
If you have that much play no doubt the fan bearing needs to be replaced.
