Puff of white smoke
Hello All,
I have searched on Smoke, white, puff....it turns up so many results I can't quite find a answer to my question. My brother has a 2001 24 valve. 100% stock. It lost a lot of power a few months back. Come to find out it was a boot on the intercooler. Fixed the low power and black smoke problem. Now, when he turns off the truck and turns it back on, cold or after running for a while. it has a huge white smoke cloud. I know that white smoke is typicly unburned fuel in the exhaust. I am not sure if is this conditon. Because it happens only when accelerating out of 1st about 5 minutes after warm or cold start. Any ideas? Thanks, y22man |
depending on temperature, white smoke could either be the water that is created with combustion or the dreaded vp44. When mine was dying i would get white smoke at start up, and anytime i mashed the throttle (before mods).
NORMAL
I would check for codes.... Key on/off/on/off/on ad watch the Odometer.
If there is no codes I wouldn't worry about it... If the dreaded P0216 pop's up you know its the VP44 is failing. |
Ok thanks for the replies.
This is in no way normal. The white cloud is like a Spy Hunter Smoke screen. And only happens when starting from a stop and inbetween shifts. Only does this with in a minute or two of startup. Again does not mater warm start or cold. Altho the inbetween shifts is a much smaller amount of white exhaust. Outside temp. is 45-70*. |
Well there is two place that oil might be entering the system and being burnt.
* Turbo Seals / Bearings (Might check for movement) * Piston Rings (Wearing) We've got a Chevy Diesel Fire Truck that is the same way. Start it up and it will fog the whole area with white smoke. We are almost total sure its a bad piston in there. But after you let it warm up a bit the smoke goes away completely. |
ok, borther finally checked the codes. This is what he sees,
P500 P460 P1693 I saw a post recently with the URL to the codes....but can't find it off hand. |
We have a list here in the Tech Facts section.
https://www.dieseltruckresource.com/...n&onlynewfaq=1 Here is another site I use a lot. http://www.troublecodes.net/chrysler/96-01.shtml phox |
| All times are GMT -5. The time now is 02:29 PM. |
