-   1st Gen. Ram - All Topics (https://www.dieseltruckresource.com/forums/1st-gen-ram-all-topics-93/)
-   -   GSK 3200 Kit installed! Non I/C Cummins (https://www.dieseltruckresource.com/forums/1st-gen-ram-all-topics-93/gsk-3200-kit-installed-non-i-c-cummins-63843/)
PapeCAT Mar 17, 2005 12:40 AM
[laugh] [laugh] Install went great thanks to Bushy's great instructions!! I Found this mod to be great. and in the end turned the fuel up enuf to gain 6 psi boost @ 30 PSI max now. I didn't grind the foot, and I noticed that the truck acts more like a gasser[yuk] but in a good way, in my case I used to have to go WOT to cruise over 70 mph not I'm at 1/4 throttle for 65 and above. I can't wait to see MPG's if they're different. But Egt's are off the chart, shot to over 1250 before I knew it!
jiMMyCTD Mar 17, 2005 07:06 AM
excellent, i ordered up mine and my fuel pin from pdr on monday! looking forward to it., right *rebal* he he, jiMMy
wannadiesel Mar 17, 2005 04:32 PM
Jimmy, you're gonna love it! Are you going to grind the AFC lever on your own or do I have to poke you with a stick? [laugh]
rebal Mar 17, 2005 05:34 PM
I think the GSK was the best bang for the $ makes the truck a little hot rod.:D :D :D :D :D
Den Mar 17, 2005 07:15 PM
Comon guys! Your killing me! My spring is sitting here on the desk.
Also have the PODs sitting here.
Have to wait till after baseline dyno on Sat
Might even wait till the exhaust and turbo is here.
And no http://dens-site.net/Dodge_CTD/poke.gif :)
Den
G1625S Mar 17, 2005 07:39 PM
the stick-poke smileys kill me every time:D
vinny Mar 17, 2005 08:31 PM
Wow,
My truck weighs 5700 lbs empty...
If your truck is a "little hot rod"...what does a "BIG" hot rod look like? :p
The only thing I can think of that's bigger is Jay Leno's 10 cyl hemi-tank engined all aluminum roadster... [laugh]
Vinny
rebal Mar 17, 2005 09:25 PM
BIG hot rod= 14N cummins in a pickup:D
Blowndodge Mar 17, 2005 09:52 PM
Man, I wish I wasn't such a woos when it comes to my pump. I'd love to put in the GSK spring but something tells me I'd screw something up. Those little parts seem to slip through my big mits!!!!
wannadiesel Mar 18, 2005 02:52 PM
It's not a bad job if you have help, but I'd hate to tackle it alone. Maybe somebody in So Cal will help you out.
Blowndodge Mar 18, 2005 04:34 PM
Thanks Dave. When I finish with my truck, I want it to look like Anthony's with his neat 18" rims, a 89% converter and 3200 spring. Right now the truck hauls buns with only the mods in my signature! All my buddies with gas trucks tell me what a fast "sled" my truck is! I can only imagine after tightening the tranny and more rpms! I'm trying to find someone in the southern cal area that knows these pumps.
brad
PapeCAT Mar 18, 2005 05:35 PM
Good luck finding someone like that. I think your best bet is right here at dtr, online! If you need assistance, I would gladly help you with your pump. I'm not a diesel mechanic but I am an FAA certified aircraft powerplant mechanic [laugh]
Nick
Blowndodge Mar 19, 2005 01:44 PM
I appreciate that! Right now it's going to be front springs, rims, tires, paint, torque converter and finally 3200 rpm spring. With gas prices the way they are, I think I'll fix up the ol' girl and hold onto her for at least 5 more years!
Brad.
rebal Mar 19, 2005 06:42 PM
Hey brad, the spring sounds a lot harder than it really is, it took me 2 hrs to install and under $25 for the spring. the only part thats not real clear (for me anyways) was the throttle shaft dissasembly and reindexing it. just take all the parts of it off 1 at a time, and the marks should be at 10 and 4 .I popped the whole arm,spring.and washers off at one time :eek: if you print the tech artical out so its in front of you it will be a piece of cake.
PS. a second pair of hands will make taking the spring off a lot easyer,I inlisted the help of my 11 year old for 5 min.
Robert
Blowndodge Mar 19, 2005 10:14 PM
Thanks Robert. Yea the indexing the throttle shaft sounds a little like something that could get messed up real easily by me! [laugh] did I understand that you also have to loosen up the pump and rotate it away from the engine too? Did you just mark a line for reference to rotate it back when you were finished? Seems like so much crap to take off just to get to the spring! I'll order it and give it a shot.
Brad
