Engine Degreaser - Recommendations
I have the thread "Do I Have a Leak (Pictures Included)" going where I show pictures of a possibly leaking oil pan gasket. I'd like to clean it up with some sort of degreaser so that I can track if it is leaking or not. But then I got to think, why only degrease that spot, why not degrease the whole engine, as it is getting a bit dirty in there. What are you guys using to do this? Am looking for some recommendations.
David |
I just take mine to the car wash, put the wand on soap, spray it real good, does a good job.
i use simple green, watch your hoses and rubber products tho, it will leave white spoots on it....
I use the neighborhood cats and rabbits. They like to sit under the hood, and when I start up they go around and around. This maintains the engine compartment in peak pristine condition. :D
I tried that once Aaron, it made more of a mess than it cleaned out...
Simple Green, covering electrical components with alum. foil....lots of water...."rinse, repeat as needed"
Simple Green here.
MikeyB |
Gunk. No white spots, no concern about foil over electrical items. I don't use high pressure spray like car washes. I have my own pressure washer. I just use the hose. IMHO, high pressure sprays can force water into places where it shouldn't be.
MY "ex" dealer where I bought my truck told me not to spay any water on it. But use an air compressor to blow of any dirt or sand.:confused: :confused: :confused:
Jamie |
I use GUNK as well. Only takes about 10 minutes on a slightly warm engine and it totally dissolves all grease and grime. Then I gently rinse with the water hose (pressure not needed with a good dissolver). I have sprayed the whole engine off with high pressure (car wash) when everything was covered with mud and didn't have any problems, but I had my fingers crossed the whole time. All of the electrical connectors have soft rubber seals to keep water out, so technically you shouldn't have a problem, but I wouldn't want to chance it routinely. Fried wiring harnesses are expensive to replace. I generally just try to keep the alternator and air box dry.
For a nice look, get some of the spray-on tire cleaner that requires no wiping. Spray everything under the hood after it has been cleaned and let it sit for 15 minutes. Everything shines and looks better than new. |
Originally posted by AK RAM I use GUNK as well. For a nice look, get some of the spray-on tire cleaner that requires no wiping. Spray everything under the hood after it has been cleaned and let it sit for 15 minutes. Everything shines and looks better than new. |
You may think that I am a thrill seeker, but I have always washed my engine(s) using the high pressure wand and the self serve car wash. I never cover anything and have never had a problem.
Originally posted by Nevada You may think that I am a thrill seeker, but I have always washed my engine(s) using the high pressure wand and the self serve car wash. I never cover anything and have never had a problem. |
Originally posted by Fronty Owner I tried that once Aaron, it made more of a mess than it cleaned out... I use the (HOT) power washer at work. Can adjust the pressure down with the wand, so it is pretty low pressure. Not much more than a garden hose. The heat gets most of it, without much effort. :D |
Simple green engine degreaser and hose for spraying off.
I will never use my pressure washer ( 4gpm 3600 psi) on my truck again after removing mud and some paint in the fender wells [duhhh] last weekend. |
| All times are GMT -5. The time now is 12:36 PM. |
