Engine Shut Down Chirp
Why is it that some 3rd gens have the chirp and some don't? My truck has never done it but in the past few days I've personally witnessed three different ones that did. [eyecrazy]
Hoss,
Mine "Chirps" at least 95% of the time:confused: Hope this is normal. |
MY buddy has a auto and his chirps every time he shuts down. I have the 6 sp manual and it never chirps.
Mine "chirps" maybe 85 % of the time...the other 15 % it kinda makes a Prissssssssssh....clank noise when shutting down, not quite sure what that is.
It is in the manual, It will do it a lot of the time.....and it is normal
I understand that it's normal, but why do some trucks do it and others don't? Mine has NEVER done it....but lately I've seen several others that have.
MY buddy has a auto and his chirps every time he shuts down. I have the 6 sp manual and it never chirps. [eyecrazy] |
My chirps. The better it's running the louder it chirps. It's music to my ears;)
I belive the gatorback belts eliminate it. Pete |
I am pretty sure it is because we have automatics and you don't....I will check in the book because it says what it is but I haven't had the chance to look it up..
The big heavy clutch and flywheel on a manual make the crank stop more gently than the lighter flexplate and torque converter on the automatic.
So now we know.....I guess. :)
When you shut down our engines there is so much compression, that the crank pulley stops turning before the rest of the pulleys, (kind of like locking up your brakes and the tires skidding) causing the serpentine belt to slip on the pulleys and make a chirp noise.
Originally posted by Tmc243 When you shut down our engines there is so much compression, that the crank pulley stops turning before the rest of the pulleys, (kind of like locking up your brakes and the tires skidding) causing the serpentine belt to slip on the pulleys and make a chirp noise. my automatic does it maybe 60% of the time. |
if ya want it to stop a little wd40 will halt that noise[laugh]
mine does it like a madman!!
almost EVERY time i stop the engine. i really thought something was wrong with it. glad i belong to a place that you can get some good quality information :D my 03 was a 6 speed and never did it but this one is an auto so that must be the cause. britt :) |
Originally posted by mikmaze if ya want it to stop a little wd40 will halt that noise[laugh] |
| All times are GMT -5. The time now is 02:49 AM. |
