| lucey |
Aug 5, 2004 11:04 PM |
Trans Temp Wiring ?
My Di-Pricols showed up today and started wiring them. The pyro has 2 positive and 2 negative connections, i believe they are wired into the headlight switch and ground. The boost is wired 1 positive and 1 negative also wired into the headlight switch and ground correct ? The trans temp guage has a lamp (1 positive, 1 negative, as well as a wire for the sender) there is one extra wire for 12v ignition. Has everyone hooked this wire to a switched 12v wire or are they just running that one to the headlight switch as well. Anyone ? One last thing, does anyone know he color of the wire for the headlight switch on the 04s ?
