-   24 Valve Engine and Drivetrain (https://www.dieseltruckresource.com/forums/24-valve-engine-drivetrain-89/)
-   -   FOOLING the ECM (https://www.dieseltruckresource.com/forums/24-valve-engine-drivetrain-89/fooling-ecm-38151/)
firestorm Jan 27, 2004 07:01 PM
FOOLING the ECM
My gauge is acting up. I know of the problems with the oil pressure sending units in our trucks, which is why I have ordered a mechanical gauge. The problem is, I can't stand the red "CHECK GAGES" light staying on.
I hate to spend $70 just to turn off that light. Below is a list of imformation to assist in solving this problem.
1: '01, 2500, 24 valve
2: The wire color codes in the harness are as follows:
Orange
Grey w/black
Blue w/black
If anymore information is needed feel free to e-mail or PM me. Thanks
thumper 549 Jan 27, 2004 07:14 PM
GO TO Cummins and get the preasure sender and let know one reflash you with the updated crap period .!
J BODY Jan 27, 2004 09:18 PM
I don't believe the "flash" for "oil psi drops off" applies to 01 trucks. A sending unit is in order.
Junk Yard Dog Jan 28, 2004 07:57 AM
Firestorm, ORANGE- 5v supply
Black/Blue- 12v pos.
Gray/Black- Engine oil pressure sensor signal
Don't have the time right now to trace the circuit, I'll check it out later
Rick
thumper 549 Jan 28, 2004 10:08 AM
if you put in the new sender it will shut your lite off
