buying a rolled truck for 2500?
ok so im looking a a dodge ramcharger cummins conversion 60 front 70 rear 3 speed 205 running gear it has some mods done to it but is there any thing i should know before i say yes it does come with a title he said it started right back up but smoked a little and it has a blue hase coming out the tail pipe. just want to know if i am waisting my time with it the body is really smashed on the drivers side i was just going to put a reg cab on it and then build a flat bed for it
thanks |
If the frame is good then go for it.. only if the price is ok. When I bought my truck the frame was rotted towards the rear. Wasn't bad at all.. nice weld and it's good to go.
Can I ask why it's $2500 for a wrecked truck ?
I paid that much for a running, street legal, rusted old truck that I got in and turned the key . No severe damage, nor frame twisted from a roll over. Might want to see if the truck's frame is tweaked before you go plopping down 2500 smackers on it. |
2500 is cheap you could Double your money just on drive train Alone as for rollover's 99% of time the body get's Destroyed but frame will be fine you could also find a crewcab and swap the stuff over also .I'de jump all over it for that price .
I dunno, the frame under my 90 Ramcharger sure doesn't look to be very sturdy with the gasser in there, add a 6BT and roll it over............:o
There Stronger then you think I rolled my crewcab and frame was Fine I broke a spring that was it
I paid $2600 to have a running truck with a rotting bed and cab towed to the shop..only 4x4 i could find that needed a trans so I may have overpaid a bit but you can still get your moneys worth out of the powertrain alone plus the scrap.
Originally Posted by Mopar1973
(Post 3114861)
(Post 3114817)
there just as strong as the diesel frames less then 1/4 in difference from what I have seen on all the truck's I have had apart .
| All times are GMT -5. The time now is 11:32 AM. |
