-   Performance and Accessories 2nd gen only (https://www.dieseltruckresource.com/forums/performance-accessories-2nd-gen-only-91/)
-   -   intermittent power loss (https://www.dieseltruckresource.com/forums/performance-accessories-2nd-gen-only-91/intermittent-power-loss-304025/)
1dumrednek Jun 12, 2012 08:54 PM
i had my truck apart this weekend to change the pushrod cover gasket, so i had the vp off and the ecm. now its running funny. it sounds way more rattly, like its running really cold. and randomly it looses power. like 3 psi boost right to the floor. no smoke or anything, its just not giving it fuel. then it cuts back in and runs normal right up to 45 psi. all the gauges on the monitor indicate good. any ideas?
KATOOM Jun 15, 2012 01:23 AM
Have you ever experienced dead pedal? Almost sounds like what you're describing.
1dumrednek Jun 15, 2012 01:55 PM
i had that once before. this is different. and i can watch the throttle % on the attitude moniter and its working fine. tried tightening the connections on the plug on hte back of the vp and didnt help
KATOOM Jun 15, 2012 03:38 PM
Maybe its something simple like a missed loose connection. But you mentioned that the VP was completely removed. Are you positive that you reinstalled it correctly and didn't misalign the key?
1dumrednek Jun 16, 2012 12:53 PM
I've been checking the connections, tightening them up, still doing it. Just unhooked the chip. Gonna try it like that.
If the pump key wasn't lined up, wouldn't it run horribly?
1dumrednek Jun 16, 2012 05:58 PM
Drove it with the chip unhooked and it still does it. I'm lost
KATOOM Jun 17, 2012 11:55 AM
If the key was misaligned then it "should" have a miss at idle. Does it run weird all the time or is this something intermittent?
1dumrednek Jun 18, 2012 08:51 AM
intermittent. and when its acting up, it only loads up to 36%.
KATOOM Jun 20, 2012 12:03 AM
Try resetting the APPS. Maybe something went awry when reinstalling since I'm guessing you disconnected the batteries.
1dumrednek Jun 27, 2012 01:27 PM
Pulled the pump back off and sure enough I didn't get the key all the way in and it sheared it off. I know your supposed to get a special key for each pump but all I had was a straight key and its running good with that
KATOOM Jun 27, 2012 01:45 PM
Thats a bummer. At least you found the problem. And yes, I understand that each VP requires a matched specific key but I couldn't say exactly why and what would happen if someone used another key.
