-   Performance and Accessories 2nd gen only (https://www.dieseltruckresource.com/forums/performance-accessories-2nd-gen-only-91/)
-   -   need input on this combo (https://www.dieseltruckresource.com/forums/performance-accessories-2nd-gen-only-91/need-input-combo-303929/)
DC199512V87 Jun 8, 2012 10:38 PM
ok so injectors and a turbo are the next upgrade [laugh] iv done a lotta research and have specific goals in mind. for now i am looking for a usable 400hp on a single turbo. im reallly leaning towards a 62/12 but have no idea what exhaust wheel size to go with [redface] theres the 65 but with a size so close to the compressor wheel wont that lead to surging?? maybe a 68 or 71? i would like to keep spoolup near stock....need ideas on this part. also the 63/68 looks appealing but thats just too many options lol the turbo also has to b compatible to make 550 hp twins down the road. injectors are sdx 5x12. question on these is with a fuel plate to control things will the above single turbo b able to clean things up smoke wise? and will these injectors b good for the 550 hp twins? kinda only wanna buy injectors once so would like to make these work for both setups eventually. truck is a toy that might tow a couple thousand pounds a year once or twice. looking for reasonable egts and low smoke.
as mentioned i have searched lots and know in general terms what i need but looking for answers to these specific questions thanks [deadhors]
95ram Jun 9, 2012 05:14 AM
That should get u close to 400 HP. I've never had a problem with surging out of the 62/65. You'll obviously need more pump mods to get to 550 with the 5x12 ie. DV's, racked barrels (benched pump). With tuned pump a 62/65 will run clean.
DC199512V87 Jun 9, 2012 11:45 AM
Ya I'm aware that other mods will b needed for sure but just trying to get these items worked out :cool: so u don't think the 62/65/12 will b too hot for ratbagging and playing?
95ram Jun 9, 2012 06:57 PM
I'd go with a 14 if it were me. I don't really see much use for a 12. I'm also not saying to not go with a 68 or 71 either. I've never tried a 68 but would have to think it's a good compromise of quick spool and decent flow.
My ideal twins setup for that ~550 range would be a 62/65/13 over an S471 w/ 1.10 housing. It should support that HP level with cool EGT's and very fast spool.
Tate Jun 9, 2012 09:44 PM
Go with 5x14's right off the bat. No need for pump mods for 550hp later down the road. I had a 64/71/0.80 (Super B Special), it was a fantastic turbo. Top gear, it would make 15 psi at 1600 rpm. Worked better than the 62/71 I had previous. Lent it to Lil Dog, he swapped it in place of his 62/65, says it drives much smoother, and no barking with it. Thats the direction I'd go again. No need for twins for 550hp with that turbo, if thats direction you want to go.
DC199512V87 Jun 9, 2012 10:02 PM
would 5x14 equal a 120 hp stick and 5x12 90hp? My only thot on a 64/71 is driving in town with a stick shift, 3.55 gears and 35s on top of that. Would I hafta run a lotta fuel to keep that 64 happy or can it b run around 400 hp for the time being? reason y I ask is cause to run 550hp I would need a dual disc clutch and upgraded input shaft and that won't b for a while, mostly cause all funds are going into injectors and turbo.
Tate Jun 10, 2012 09:35 PM
Other than 35's, thats what my combo was. Like I said, that 64/71 is a magical turbo. 5x14's are usually referred to as a 140hp injector. You can back the plate off to put the fuel where you need it. Do the clutch first. If you're in aftermarket injector territory, you're in new clutch territory. I killed my stock clutch with just a 10 plate.
With the stock turbo and 5x14's, I did 330hp. 62mm turbo, 440hp. With my twins, its 520hp. Only thing that changed was the turbos, and I bumped the timing after I did the head. The last dyno was on a no-load dyno the dragging the brakes to get the turbos going. If it was on the same dyno as the first couple runs, I'm sure it would have been mid 500's.
There is a myth that you need X amount of fuel to make a turbo drivable. You need fuel to take full advantage of it. Driving around with the plate full rearward or full forward, you won't notice a difference until you give it some throttle. 64/71 daily drives very well. The 66/73 I had was a different story.
95ram Jun 11, 2012 05:24 AM
And in my experience going from stock size tires to 35's, what I have now and ususally run, makes a big difference. It doesn't seem like it would but it's a lot more rolling resistance. Takes more to get the trubo going.
DC199512V87 Jun 11, 2012 12:13 PM
Tate u sound like a go big or go home guy lol[laugh] I like the sounds of that....definitely leaves me room to grow for sure. 95ram I'm a bit confused u like or don't like the 35s? I'm looking for tires right now anyways and am torn between the looks of the 35s or raising the gears a bit with like a 285.....[duhhh]
Tate Jun 11, 2012 10:36 PM
I run 285/70R17's, so they are the same as a 33. I run 235/85R16's in the winter time. Other than being harder to run the steering wheel with the 285's, I really don't notice much difference.
Mike Holmen Jun 12, 2012 02:04 PM
We have had good luck running 7 hole nozzles. Ran both the 7X10's and 7X13's on a slightly tweaked 160HP pump 20 deg's of timing, (4gsk, plate removed, afc adjusted for more down low fueling, barrells racked). The 7X10's was set at 290 bar and the 7X13's was 300 bar. The 10's hazed at idle more than the 13's, but was more to the lower pop pressure. Both 7 holes were less smokey than the SAC 5X12's or 5X14's. Hard to beat the pricing on the sac nozzles.
DC199512V87 Jun 12, 2012 08:00 PM
how were those 7 hole injectors up top? iv heard that the 5s fuel harder up top (higher rpms) whereas the 7s have a bit more low end. not sure on how valid that is, but hard to beat the price on the 5 hole sdx's.....[duhhh]
HOHN Jun 14, 2012 08:57 PM
This is generally true ^^. I can't speak to the specific parts in question, but I can tell you that fewer, bigger holes generally works best at higher RPM and more, smaller holes generally pulls better on the bottom.
The reason is related to how diesel fuel combusts, and the effect of flow vs mixing. At low rpm, mixing is poor and you need better atomization. At high rpm, there is so much chaos in the cylinder that does the mixing for you, and you need the big flow to minimize the number of crank angle degrees it takes to spray in the fuel.
JH
95ram Jun 14, 2012 11:08 PM
I love my 35's I run them on all my pickups. I like the looks and they give me the ground clearance I need in the the winter. The problem is the do effect you bottom end power. 285's are a good choice too. I may have to go back to 285's on my next go round.
DC199512V87 Jun 15, 2012 09:55 PM
just gotta make more power so u can turn them like a 285! [laugh]
