-   4th Gen High Performance and Accessories 2010 and Up (https://www.dieseltruckresource.com/forums/4th-gen-high-performance-accessories-2010-up-200/)
-   -   35" tire pressure (https://www.dieseltruckresource.com/forums/4th-gen-high-performance-accessories-2010-up-200/35-tire-pressure-303906/)
chopper698 Jun 8, 2012 04:11 AM
35" tire pressure
For those that are running 35" on stock
rims what air pressure are you running
unloaded?
6.7L MegaCab Jun 8, 2012 06:54 AM
I don't run 35s but the tire shop I use to work at , it was policy to inflate over size tires to the same psi as indicated on the door sticker. Justification: tire pressure is based on the best wear for the weight of the vehicle, among other factors. The weight of the vehicle didn't change much. We never had trucks/suv's coming back due to under inflating or over inflating causing the tire to wear out quicker on the sides (under inflate) or down the middle (over inflate). When customers came in for tire rotations, tires always wore evenly. Just my thoughts.
Sent from my DROID X2 using Tapatalk 2
SOhappy Jun 8, 2012 01:49 PM
I run my 33"s at 50-55psi in the winter* for better traction and 60-65psi in the summer for better fuel economy, 70psi when towing. They seem to be wearing evenly.
*Just don't forget to air them up to at least 60psi when towing or the EVIC will give you a tire PSI warning message.
chopper698 Jun 8, 2012 01:57 PM
65 is the max for my 35"s, I went with
what it says on the inside of the door
60 front 45 rear for light load. I disabled
the TPS through the mini max. I found
it more comfortable with 50lbs in the front.
tcr Jun 9, 2012 08:49 AM
60/45 here, I like the assistance in turning more air pressure provides. I have 9" wide wheels so I get more tread contact area w road surface and while they will wear the center faster I like the turning ease 60+ psi provides.
Rednecktastic Jun 12, 2012 10:52 AM
At 50lbs just check the sag in the tire by stepping back and looking at them front to back. Not an exact science but good enough for me and my truck.
I believe I ran 55-60 fronts and 40-45 rears on both my E and D rated 35's. On the D rated if I recall correctly it was like almost 60 front and around 40 rear to keep the sag even. Not the right tire for the application though and went with E rated to be proper.
I'd probably stay in the parameters of the pressure listed on the tire and not on the door if you change from factory tires.
LOWTYD Jun 14, 2012 08:43 PM
35 toyo MT's
I've run the following pressures in every set of MT's I've owned. Unloaded, 45 in the fronts and 35 in the rears. This is on stock wheels. I keep about 300 lbs of playsand in the bed during the winter and air up to 45 in the rear then. I averaged over 65k on every set of MT's so far, and installing my 3rd set next week. It would take a lot for me to consider changing.
Julian Rich Oct 4, 2017 08:36 AM
is this on a dually
LOWTYD Oct 4, 2017 05:52 PM
Originally Posted by Julian Rich (Post 3336195)
is this on a dually
No...this is on a single rear wheel. However, I'd say that these pressures would work fine on DRW. When hauling I run 65psi all around. Still the best tires ive ever owned.
Mexstan Oct 4, 2017 08:50 PM
A little trick that you can try is to run a wide chalk line across each tire in a couple of places. Then take the truck for a short ride and see where the chalk vanishes. Nothing in the center of the tire, then it is probably over inflated. If it is rubbed off at the edges, then maybe it is under inflated. The chalk should rub off evenly all across the tire.
Danderson Oct 4, 2017 10:21 PM
Yeah,the chalk test said I had even tire footprint.
I run my Toyo AT2's@ 50 psi F&B. They're like rocks.
My front axle weight is 4400#,rear is 4000#. This is with my 1800# camper on all the time.
With 8" stock rims the 35's will wear prematurely in the center at even 60psi on mine. The manufacturers recommend a 9" rim for 35-12.50-17'/18's. This results in even wear and a more stable tire.
LOWTYD Oct 5, 2017 07:22 AM
How do you like the AT 2's? I've considered them for my next set, but hard to go away from the MT's.
McGyver May 5, 2020 12:09 PM
The chalk test is just like the 'dirt line' test I always keep an eye out for knowing if my pressures are correct. The door sticker is only good when the truck is stock equipped.
