-   4th Gen High Performance and Accessories 2010 and Up (https://www.dieseltruckresource.com/forums/4th-gen-high-performance-accessories-2010-up-200/)
-   -   my 2011 and deletes (https://www.dieseltruckresource.com/forums/4th-gen-high-performance-accessories-2010-up-200/my-2011-deletes-303145/)
cfdlighthouse May 10, 2012 03:35 PM
my 2011 and deletes
Hey, Just wanted to share my experience with my 4th gen and deletes...most of my pictures are post work but illustrate the changes none the less. ALL i can say for those on the fence is save up the money and do it....
my new truck dealer shinny
https://www.dieseltruckresource.com/.../500/new13.JPG
Add 35" 12.50 17 michey thompson ATZ
https://www.dieseltruckresource.com/...00/tires11.jpg
Add Hell Bent Steel 2.5 leveling kit and steering brace...took about 3 hrs in the drive way to do....the faster you put that on the easier all the bolts a come loose
https://www.dieseltruckresource.com/...0/leveled1.jpg
https://www.dieseltruckresource.com/...bslevelkit.jpg
https://www.dieseltruckresource.com/...ringbrace1.jpg
and some bilstein 5100's
https://www.dieseltruckresource.com/.../500/b5100.jpg
as more money came in the DPF delete stuff started to arrive all to include magnaflow 4 inch exhaust and 6 inch tip, 4 inch MBRP delete pipe no bungs
https://www.dieseltruckresource.com/...haustangle.jpg
https://www.dieseltruckresource.com/.../magnaflow.jpg
no muffler and no DPF
https://www.dieseltruckresource.com/...deletepipe.jpg
everything came out and went on super easy took less than an hour to unhook, un bolt, and re-install new pipes
cfdlighthouse May 10, 2012 03:36 PM
Then i went to the engine, AFE stage 2 CAI, sinster egr and cooler delete, GDP throttle valve delete, and GDP open breather
https://www.dieseltruckresource.com/...estage2cai.jpg
https://www.dieseltruckresource.com/...0/sinister.jpg
https://www.dieseltruckresource.com/...olerdelete.jpg
https://www.dieseltruckresource.com/...dptvdelete.jpg
https://www.dieseltruckresource.com/...ndbreather.jpg
Engine compartment is soooo clean and uncluttered all installed without any issues...there was one bolt on the egr cooler exhaust elbow that needed a crows foot to get to, but my truck had less than 5000 miles on it and onc ethe bolts were loose they all came right out..... the install was easy and everything fit just like it was supposed to...about 3 hours for all the engine mods and this is what was left over
https://www.dieseltruckresource.com/...weightcut1.jpg
https://www.dieseltruckresource.com/.../weightcut.jpg
https://www.dieseltruckresource.com/...weightcut2.jpg
I didnt have any soot problems in the intake like u see in alot of the pictures, but i have not run the truck hard either.
I elected for the smarty jr67me because it gave me everything i needed for the cost, just have to add a pyro and ill be set for awhile... i truely have a very easy tear down and install and have been pleased with all the help and advice i have gleaned over the past 6 months her from others on the site while i have been stock piling parts. love the power and fuel mileage gains...i am getting around 20 average now, the truck sounds like a diesel and runs great!!
Big Swole May 10, 2012 08:21 PM
Nice truck and nice thread about the mods!! Thanks!
Just ordered my mini max and delete pipe.. I'm just gonna do the stealth deletes for now.. Since the MM just turns off the EGR system and unpluging the T. Valve locks it open.. Should be just about the same gains, just not clean under the hood...
Did you not do a head bolt retorque or studs yet?
I'm just gonna retorque my stock bolts to 135 or so & then roll with some extra power... Not gonna get crazy though.. I'll buy another race truck / toy for that some time.
I'm also gonna keep the stock down pipe and resonator (some call it the muffler)... I want it to stay quiet and with no drone..
cfdlighthouse May 10, 2012 08:48 PM
thanks.....i run the smarty on standard tune and am not looking for crazy power...just efficiency....clean healthy motor...clean oil.....and leting the engine breath in and out the way its supposed too. I have read about studs, but if you are turning up the tune to the point that boost is threatening your head gasket seal, there are probably collateral effects on other systems.....like you said if you want monster power build a truck to take it...i just wanted my truck to run free a bit.....however the addiction is hard to resist....
Blake Clark May 11, 2012 07:54 PM
Good looking truck and Im glad to see you are enjoying the deletes.
cfdlighthouse May 12, 2012 02:04 PM
thanks...this is my third one and by far my favorite truck!!
cfdlighthouse May 14, 2012 08:05 AM
parts and costs
I figured i would add a parts list with part numbers for my truck (2011.5 2500 4x4 crew cab long bed) where i got the parts from and how much it cost...just more info for those who are looking to do this....I shop around for the cheapest prices so i went through several vendors along the way
HellBentSteel.com
2.5 Level Kit p# 110-250-001 $80.00
steering stabilizer bar p# 170-009-001 $140.00
Autoanything.com
AFE Stage 2 CAI with prodry s filter p# 51-12032 $290.00
Xtremediesel.com
Mbrp delete pipe with no bungs p#mbcdal437 $114.00
(don't forget to fill out waiver)
Shockwarehouse.com
Bilstein 5100's front shocks(2) p# F4-BE5-6681-H8 $160.00
Mkmcustoms.com
Sinister EGR valve/cooler delete p#smc-egr.6.7c1 $140.00
Glacierdieselpower.com
Bigbore throttle valve delete-black p# 07510-350-tvd $69.00
Open breather kit p# 07510-vcb $40.00
Amazon.com
Gorilla splined lug nuts p# 26195ht $68.00
Performancetruckproducts.com
Magnaflow Pro 4" DPF back exhaust p# mfl-17917 $285.00
(no muffler)
Thoroughbreaddiesel.com
Smarty jr tuner p# sjr6710me $495.00
Discounttiredirect.com
American Outlaw Buckshot Rims p# 17x98-165.115mtb $488.00
17x9 matte black
Thats my list so far.......
cfdlighthouse May 16, 2012 12:49 PM
my cabin filter mod
I did the cabin fiter mod after pollen season and the inside of my truck getting covered in yellow from the unfiltered air intake.
glove box comes off super easy - just push in the two tabs for the retaining lugs and remove.
this is what you look at...with the un cut filter door area
https://www.dieseltruckresource.com/...ltercutout.jpg
just cut the rectangle out...the plastic is really thin...a sharp blade is all you need from a utility knife just takes a few minutes and this is what you get.
https://www.dieseltruckresource.com/.../door_cut1.jpg
plastic removed just insert filter
https://www.dieseltruckresource.com/..._filterin2.jpg
and snap the door cover on...its super easy
https://www.dieseltruckresource.com/...rinstalled.jpg
thats it...
chrysler filter and door ordered online...delivered to the house for 30.00 now no more dust inside the cab!!!
53C12 May 17, 2012 08:59 PM
Thank you for the post greast info. just purchased a 2012 manual, looking to do the same mods. Do 2012 not have cabin filter either?
cfdlighthouse May 18, 2012 07:00 AM
cool, i hope you enjoy it ....as far as the cabin filter i am not sure about if they added it for 2012....its real easy to check though...just push the tabs in on the glove box and remove it and look to the air box either you will see the first picture with an uncut panel or the last picture with a air filter cover
cfdlighthouse May 18, 2012 07:02 AM
oh 53c12 - just read your sig line....stay safe..... im in PF Local 2803 in VA
Blake Clark May 18, 2012 07:16 AM
FYI the Wix cross for the cabin filter is 24578.
Just snagged 3 of em from Amazon for 30 bucks.
cfdlighthouse May 18, 2012 08:51 AM
Awesome, thanks i was gonna order some to have available..i will hit up amazon too.....and i am a fan of wix filters air, oil, fuel etc.
cfdlighthouse May 18, 2012 10:00 AM
more part numbers and $$
Wholesalemopar.com
Chrysler cabin air door pn# 68052292AA $9.00
Chrysler cabin air filter pn# 5058693AA $15.00
Cabin air cross by Blake (thanks)
Cabin air by Wix pn# 24578 $10.00
Other Wix ## also from Amazon.com
Fuel Filter pn# 33255 $45.00
Oil Filter pn# 57620XE $14.00
(i use the extra efficiency one.. the regular is just 57620.. but with the XE it has the flutes on the bottom for better gripping)
Transfilter deep pan pn#58843 $26.00 (thats pan filter, spin on and gasket)
cfdlighthouse Jun 4, 2012 06:41 AM
Smartyjr and new updates
I just ran the software update for my smartyjr me and it has improved throttle response and turbo spool up. not sure about any of the other levels but i had it on sw#1 before and left it there and i drove it before and after the software update and there is a noticable difference.
So aside from timing etc i was interested in what the actual proposed numbers were. since there is no really definitive hp settings or literature that explains what the levels mean, i emailed mads electronics and here is what they said.
for 2010 and up there are 5 levels on the smartyjr
in the smarty they are labeled
(stock(x), standard(sw#0), fuel economy(sw#1), towing(sw#2), and performance(sw#3))
here is what mads says
Stock = factory settings with all emission systems active erg/dpf etc.
Standard = stock programing with emissions DPF/EGR/tv systems functions etc. eliminated/deleted
Fuel economy = +40hp
Towing = +70hp
Performance = +100hp
Thanks to Gianfranco Castano from MADS for getting back to me so quickly
hope this helps everyone elese who had no idea what stock,standard, fuel economy, towing, and performance meant.
