-   1st Gen. Ram - All Topics (https://www.dieseltruckresource.com/forums/1st-gen-ram-all-topics-93/)
-   -   no heater fan or power window (https://www.dieseltruckresource.com/forums/1st-gen-ram-all-topics-93/no-heater-fan-power-window-299930/)
Reapertura Jan 28, 2012 02:06 PM
like the title says that stuff is no longer working, i checked and all fuses look good. if its a fusible link where is it, how do i check and how do i replace it. a pic would be great to. thank u guys or if you have any other ideas to help me thank you.
simplysmn Jan 28, 2012 02:49 PM
fuseible link are on driver's side fenderwell by hood hinge
bill-d-c Jan 28, 2012 03:45 PM
On my 92 it turned out to be the ignition switch. I was told both are on the same terminal. Anyway, it fixed mine.
Bill
Reapertura Jan 28, 2012 04:33 PM
i checked the wires and none are burnt or broken and ignition is new, unless the switch is somewhere else
gyman98 Jan 28, 2012 05:28 PM
You need to check the fusible links with a test light, the ones by the drivers side hood hinge. I "think" its the pink one
Reapertura Jan 28, 2012 06:47 PM
ok thanks, the only one i can identify by color is orange
Reapertura Jan 29, 2012 04:58 PM
i replaced the pink fusible link and still nothing? anymore ideas
MARF75 Jan 29, 2012 06:11 PM
I thought it was orange but can't swear to it.
Try taking off the plastic on the steering column and checking under there.follow back off the ignition switch. Pink/black wire and black/orange wires and look for burnt plugs. Hope it helps
Crossy's son Jan 29, 2012 06:16 PM
Fusible link. Had to replace mine the other night. It's the one that won't have power on the firewall side of the link when you probe it with a test light
Reapertura Jan 29, 2012 06:56 PM
ok ill check more tomorrow thanks for the input.
Reapertura Feb 6, 2012 02:07 AM
checked all links and they are all good. but I have no power to the fuse for the blower i think.
MARF75 Feb 6, 2012 05:57 AM
Check the above mentioned wires in the column!
They are probably burnt at the ignition switch and not getting power to the fuse block
j_martin Feb 6, 2012 08:47 AM
These are old trucks. Heater fan motor would be considered a consumable as they have internal parts that normally wear when used. Power to it goes through 3 switches and a fuse, along with a dozen or more connectors, all of which can fail. The coarse stranded wires going through the flexible wire loom in the door hinges are pretty famous for breaking.
Get a wiring diagram, a meter or test light, and have at it in a logical fashion, or you'll either go broke, or accidentally crank in more problems trying to fix it.
I'd post a link to diagrams, but I have no idea what yer working on.
MARF75 Feb 6, 2012 09:02 AM
Also, I am a wiring moron, and I got my hands on a FSM (factory service manual) and it`s priceless! Get one if you don`t have one, all the diagrams are in there.
ppiggppenn Feb 6, 2012 10:42 AM
Ditto that, ... I got a digital one (CD) from Geno's for about $35, ... this way always with me in one form or another, ..
