-   Towing and Hauling / RV (https://www.dieseltruckresource.com/forums/towing-hauling-rv-95/)
-   -   Electric brake problems (https://www.dieseltruckresource.com/forums/towing-hauling-rv-95/electric-brake-problems-298727/)
fastlane Dec 23, 2011 07:17 PM
I have a hayes energize 3 proportional brake controller, when I step on the brakes, no trailer brakes. When I slide the manual brake controller, brakes work. I wonder if it has something to do with my truck?
Totallyrad Dec 23, 2011 07:28 PM
It's a pendulum type. Check to see that the pendulum is properly adjusted.
chaikwa Dec 23, 2011 07:59 PM
Sounds like either the controller bit the dust or it lost its' signal coming from the brake pedal/stop light switch.
rich Dec 23, 2011 11:18 PM
i'm with rad check the pendulum first and then if its getting power from the brake pedal.
rebal Dec 24, 2011 11:41 AM
Dido on the above .mine ended up biting the dust ,also had a prodigy do the same thing.been using P3s in the trucks but will be phasing in brake smarts next round
Robert
torquefan Dec 24, 2011 12:07 PM
My old Energize eventually started doing that as the potentiometer inside started wearing. The proportional braking never disappeared completely, it just got more erratic than normal. ;) I limped it along for a while by changing the level setting a bit, so the contact would catch it in a different place. I finally decided I might as well move up into the 90s, so I replaced it with a Prodigy.
fastlane Dec 31, 2011 04:27 PM
It is fairly new (2-3 months old) I will have to check the pendulum thing, unfortunately it will be 4-6 weeks from now, been in an accident and am unable to drive.
