-   24 Valve Engine and Drivetrain (https://www.dieseltruckresource.com/forums/24-valve-engine-drivetrain-89/)
-   -   vacuum pump/power steering pump leak (https://www.dieseltruckresource.com/forums/24-valve-engine-drivetrain-89/vacuum-pump-power-steering-pump-leak-26632/)
amartinson May 4, 2003 01:55 PM
Just had my truck into a dodge dealer three weeks ago for an engine oil leak at the vacuum pump/powersteering pump assembly. I was told by them it was just a seal in the vacuum pump but that the part was not available from dodge. They said they would have to replace the pump for $1100.00. I took the truck to my local Cummins dealer and had the pump rebuilt for $300.00. It is now leaking again and will have to go back in. Is this a common problem or am I the only one? Could it be possible that the engine oil leak is acually coming from the powersteering pump and not the vacuum pump?
