-   1st Gen. Ram - All Topics (https://www.dieseltruckresource.com/forums/1st-gen-ram-all-topics-93/)
-   -   He351cw Exhaust Housing (https://www.dieseltruckresource.com/forums/1st-gen-ram-all-topics-93/he351cw-exhaust-housing-266171/)
smalltownram Mar 16, 2010 08:08 AM
i just got a he351cw but i has an inch long crack in the exhaust housing where can i get a new onw
dkimmel Mar 16, 2010 08:17 AM
check ebay
smalltownram Mar 16, 2010 08:22 AM
no luck
Benjamin b2 Mar 16, 2010 03:49 PM
are the housing on 341's the same as the 351's, if so try and find a cheap 341 and swap housings
Rick 12v CTD Mar 16, 2010 06:25 PM
the ex wheel is smaller on the 341 so even if the rest of it is the same you'll have to machine it out I would think.
Jer12377 Mar 16, 2010 06:43 PM
What about welding it? There is some nickel rod out now that doesn't even require pre or post heating.
JustRamIt91 Mar 16, 2010 08:59 PM
Sweet!! I've just braised in the past, the stuff i used was basically like a super solder. It would become tough as nails after it cooled...
Jer12377 Mar 16, 2010 10:18 PM
I don't think braising will work on a turbos exhaust side. If I remember correctly braising rod melts at around 800* and my EGTs have gotten up to 1500*. Cast iron and nickel melt at over 2000* where I think the welding part would be needed. I think the braising will weaken enough to re-crack with the high exhaust temps. I might be wrong and I hope someone more knowledgeable corrects me if I am, but that's just my two cents.
JustRamIt91 Mar 16, 2010 11:10 PM
i was talking about a cast iron intake manifold, not necessarily a turbo housing. Thats why i thought it was sweet that they came out with a nice nickel rod.
