-   3rd Generation Ram - Non Drivetrain - All Years (https://www.dieseltruckresource.com/forums/3rd-generation-ram-non-drivetrain-all-years-101/)
-   -   Inverter Install (https://www.dieseltruckresource.com/forums/3rd-generation-ram-non-drivetrain-all-years-101/inverter-install-263974/)
Blake Clark Feb 14, 2010 03:56 PM
Inverter Install
Hey Yall
My lil 225 watt power outlet plug inverter just gave up the ghost. Decided to do a bigger inverter and a permanent install. I love the 110v outlet in the new 2010's so I decided to do something kinda similar... lol
I have the bucket seats with the bucket seat console and wanted a plug in the big well by the cupholders and one that could be accessed from the back. I really wanted a pure sine wave inverter but didnt feel like dropping the coin on it. Got a 1000w continuous and 2500w peak for 139 bucks. Wiring and a few other supplies and it totaled out to about 210 bucks for the whole install.
I started by removing the rear panel where the a/c vents are. It just clips into place, similar to the radio bezel clips.
http://i557.photobucket.com/albums/s...k/P2130048.jpg
The front console came out too.
http://i557.photobucket.com/albums/s...k/P2130050.jpg
(the other wires are for my ipod control and remote bass for the amp)
I took an extension cord and hacked it up to provide the power to the sockets. I didnt want to chop up the new inverter too much so I just made some new plugs that way If I want to take it out and use it elsewhere I can.
http://i557.photobucket.com/albums/s...k/P2130051.jpg
Inverter itself was mounted under the seat and the wiring through the carpet to the underneath of the console.
http://i557.photobucket.com/albums/s...k/P2130052.jpg
I also wanted easy access to the interters power switch so I did remove it from the inverter, extended it and installed it where the power pedal switch would be.
http://i557.photobucket.com/albums/s...k/P2140053.jpg
The plugs I used were from the old inverter. I used the face of the inverter as a template and used a dremel to cut the holes. The plastic was thicker than the face of the inverter so the plugs wouldnt clip in. They got welded in with a healthy dose of gorilla glue and I let them set hard before messing with them.
Here is the plug from the rear and hooked up to the extension cord.
http://i557.photobucket.com/albums/s...k/P2140054.jpg
http://i557.photobucket.com/albums/s...k/P2140055.jpg
The inverter was wired with a good 8 gauge amp wire with a glass inline fuse.
Final pics in the next post.
Blake Clark Feb 14, 2010 03:58 PM
Here are the final install pics. I dont like the remnants of the gorilla glue around the plugs, but it was the only option I had. I can say this, they sure aint going anywhere now...
http://i557.photobucket.com/albums/s...k/P2140056.jpg
http://i557.photobucket.com/albums/s...k/P2140058.jpg
http://i557.photobucket.com/albums/s...k/P2140059.jpg
http://i557.photobucket.com/albums/s...k/P2140060.jpg
See yall later!
Blake Clark Feb 14, 2010 04:00 PM
Man, I just looked over this post and realized how filthy my truck is....
Dang pipeline Right Of Ways....
Guess I know what Im doing next Sunday! [laugh][laugh]
06dodge4x4 Feb 14, 2010 08:15 PM
I like what you did. I did a similar install but used the square part of the center console to mount a receptacle. I also ran wires to the my grille guard and rear bumper so I can run things. (My inverter will run the furnace in my house in a pinch!)
