-   3rd Generation Ram - Non Drivetrain - All Years (https://www.dieseltruckresource.com/forums/3rd-generation-ram-non-drivetrain-all-years-101/)
-   -   2wd Sway Bar Diameter/End Link Bushings - Replacement (https://www.dieseltruckresource.com/forums/3rd-generation-ram-non-drivetrain-all-years-101/2wd-sway-bar-diameter-end-link-bushings-replacement-259850/)
mdbrown Dec 20, 2009 10:25 AM
Hi All,
I'm looking to go to polyurethane bushings for my front sway bar mounts and end links. I've used Energy bushings on other trucks, but will have to go with Energy universal sizing for this project, as they don't have a vehicle specific set of bushings per their website catalog.
So, I need to know the diameter of the of the stock sway bar on my 2004, 2wd, 3500. I don't have calipers, so I don't have a good way to determine the exact diameter.
If anyone out there can provide this info, along with the size of the end link bushings needed, it would be greatly appreciated.
.boB Dec 20, 2009 11:39 AM
Got a set of open end wrenches? They're pretty good for measuring the diameter.
MikeyB Dec 20, 2009 01:12 PM
I measured mine, 1.18" (30mm).
MikeyB
mdbrown Dec 21, 2009 09:38 AM
MikeyB - Did you swap out your rubber bushings for polyurethane ones? Did you use polyurethane end link bushings?
If so, I would love to know what brand/size you went with.
Rednax Dec 26, 2009 02:20 PM
Mine needs this done, too. Have upgraded our two 2WD Jeeps this way as well as other cars in past. Poly bushings here, and on shocks, is a noticeable upgrade for steering precision.
Sevir Dec 26, 2009 08:18 PM
are yall getting a clunking where you turn or hit bumps. i am getting this, it sounds like teeth on a bolt is scrapping or something like that. I troubleshot it down to the sway bar but just havnt replaced it yet.
MikeyB Dec 26, 2009 08:48 PM
Nope, still running the originals. Every once in a while I'll hit them with some silicon spray to prevent galling.
I did have to replace both end links a few months ago, not because of the bushings but from the ball joints being worn out and rattling. I went aftermarket using Deeza.
MikeyB
