4WD Enguagement Problems
So, typical problem xcept mine pops in and out. I took it out and inspected it(CAD) and all is good. I have replaced most of the upper hoses and the two that come from the CAD. It looks like there is some oil in the lines also.I have around 25 lbs. of vaccume just after the pump. Maybe the lines on top of the Tranny?[verymad]
Originally Posted by coloblacksmoke
(Post 2634066)
Originally Posted by Digital Bullet
(Post 2634154)
I bet its the plug that goes in the top of the transfer case.
check the rubber connections on the vac line common spot is at the transfer case .oil gets on them and they get mushy and they don't seal tight any more any movement makes the transfer case kick out also the plastic tubing can crack
When you had the CAD out did you take a look at the ends of the intermediate shaft? When they aren't being held in tight they can slope the end of that shaft off and it won't hold no matter what. That's one reason I went to the Posi-lok, didn't want to have to worry about it anymore.
So I started off by splicing a tee into the vac.line and running a hose strait to the engage side of the CAD, started truck and yep 4WD is engaged. Next I found out online that the green vac. line is a vent, so I took my plug out and put the vent back in. So next I put new vac. line from the hard line to the rubber boot(plug) and nothing, so I put my vac pump on the steel line that goes to the engage side of the CAD that's on the frame, I started the truck and pushed over on the boot and got vac. I don't know when I can get a boot so I took it out and hooked the rubber vac. hose directly to the plastic nipples and the 4WD works great. Later Rocky[guitar]
(Post 2638157)
Homemade Posi-Loc might be cheaper and longer lasting than fixing the CAD.
Instructions> http://www.jeepforum.com/forum/showthread.php?t=595515 |
Thats a cool idea; I check out that Jeep forum a lot. (I have a 91 cherokee).
Thanks for the post, my 4x4 quit working also, but now we're in the middle of the engine swap. |
Originally Posted by infidel
(Post 2639095)
Instructions> http://www.jeepforum.com/forum/showthread.php?t=595515 hole and add washers till the fork is tight then put nylok nut on other end making sure the fork is in what would be in the engage position throw some silicon in the holes and tighten nuts, engage coupler and bolt back up. Don't forget to plug both vac. lines and tape up the plug for the 4WD. Guaranteed 4WD.Since I only drive 3 blocks to work and maybe 60mi. round trip on the weekend to go snowmobiling It should be alright till a perminant fix. |
The green vac line is supposed to vent to atmosphere to vent vacuum when things are being disengaged.
Joel |
| All times are GMT -5. The time now is 04:35 AM. |
