-   24 Valve Engine and Drivetrain (https://www.dieseltruckresource.com/forums/24-valve-engine-drivetrain-89/)
-   -   High idle after using cruise on interstate (https://www.dieseltruckresource.com/forums/24-valve-engine-drivetrain-89/high-idle-after-using-cruise-interstate-257542/)
ted_pulliam Nov 20, 2009 09:07 AM
I notice that my idle increases by 75 or so rpm after a run down the interstate at 65 - 70 miles per hour with the cruise set.
When I stop the engine and restart it the idle drops back down until the next time I use cruise.
What could be causing this?
Ted
rebal Nov 20, 2009 11:31 AM
mine will go up 100-150 after a long run on CC. its sorta strange but has not left me stranded I dont know if its in need of a reflash or what, but I wont take my truck back to the dealer for nothing. my truck is not stock anymore.
ted_pulliam Nov 20, 2009 12:42 PM
thanks rebal. I won't worry too much about this since the truck runs good otherwise.
Ted
SWC Nov 20, 2009 08:53 PM
When I had this problem the Pacbrake would not engage. This all tied into the APPS going out on me. If you have no other problems don't worry about it. I found away around the exhaust brake problem and put up with the idle issue for 4 years. When I started having dead pedal issues on a trip I replace the APPS and everything is fine now.
Stan
ldornak Nov 24, 2009 12:40 PM
x2 on the APPS. I had the exact same issue - high idle after using cruise. I replaced my APPS and the problem went away.
sheriffav8r Nov 27, 2009 11:07 PM
It's totally normal. Do a search on it an you will see that the PCU/ECU has numerous idle speeds based on countless paramaters. You're experiencing the "cruise idle" that happens sometimes after cruising at highway speeds....
Captain Coop Nov 29, 2009 12:19 AM
Had the exact problem however mine would idle to almost 1200 RPM. Mine was the APPS and after replacing it that stopped but it would still idle up just a little bit after cruise was engaged for a while or just after running at highway speeds for a while. That is normal. Ive heard that its something to do with all the sensors readjusting and it just takes a second??? but it is normal.
ted_pulliam Nov 30, 2009 09:08 AM
Thanks everyone. I can live with the high idle for now :-)
Ted
