-   Performance and Accessories 2nd gen only (https://www.dieseltruckresource.com/forums/performance-accessories-2nd-gen-only-91/)
-   -   Drag comp vs. Adrenaline vs. Redline box...same dyno, same truck, same day! (https://www.dieseltruckresource.com/forums/performance-accessories-2nd-gen-only-91/drag-comp-vs-adrenaline-vs-redline-box-same-dyno-same-truck-same-day-255830/)
J Lent Oct 28, 2009 05:52 PM
I just bought a Drag comp version 10.8 & I am heading to the dyno this saturday to see which box is putting it down. I plan on running the Drag on 5x4 first run. Second run, Adrenaline Dyno tune [or whichever Quad tells me to run], 3rd run, Redline 93% with Drag comp on timing. Any early bets which box will prevail?
Dinner Oct 28, 2009 06:10 PM
Neither, you'll blow up your engine before your 3 results are taken! haha just jokin'
I'm thinking the Redline...unless the Adrenaline is running well that day than I dunno. Good write up/testing you will be doing though!
J Lent Oct 28, 2009 06:37 PM
You know I like to put everything out on the table.LOL I wanna see what is up with the 3 boxes, no B.S.
DIESELWRKS Oct 28, 2009 10:28 PM
no Jinx on the manifold.[laugh]. I really hope its not something that I will have to buy later because of you. I know you will do a good posting on this. are you the operator or is someone else pulling the trigger. what gear is the best for a 5 speed.
good luck J.
J Lent Oct 28, 2009 10:31 PM
I'm not sure if he will let me run or not? This manifold better not bust. Junk crap
Mike D Oct 28, 2009 10:53 PM
I would guess a drag comp if it was an older version not sure how the new versions run. Too bad you didn't have a TST to throw in the mix.[coffee]
psd tuner Oct 28, 2009 11:00 PM
i dunno i would like to see how this plays out. ought to stack a smarty with them, just to see how that works out.
Diesel- Dummy Oct 29, 2009 06:29 AM
me tooooooo
J Lent Oct 29, 2009 07:13 AM
Send me a TST & I'll gladly do it.[guitar]
J Lent Oct 29, 2009 07:15 AM
I have seen dyno sheets using the Comp/Smarty stack, it loses about 30hp. The Adrenaline came alive with Smarty loaded on my truck above 3200, but lost 25hp before 3200rpm.
J Lent Oct 29, 2009 07:19 AM
My dyno sheet from last october.
1 Attachment(s)
Run 1 Adrenaline/Smarty stack
Run 5 Redline/Adrenaline stack
Run 6 Redline/Adrenaline/Smarty
Attachment 30099
stevewes2004 Oct 29, 2009 09:24 AM
sweet, did you have the same injectors and turbo then as you do now?
Mike D Oct 29, 2009 09:51 AM
If I wasn't an addict I would.[laugh]
J Lent Oct 29, 2009 10:30 AM
Onernight it now & I'll have it back to you Tuesday.[laugh]
J Lent Oct 29, 2009 10:31 AM
I had a 62/71/14 before, but same injectors. I now have a 64/71/14 Bd Special.
