-   HELP! (https://www.dieseltruckresource.com/forums/help-97/)
-   -   Need HELP! truck running very bad (https://www.dieseltruckresource.com/forums/help-97/need-help-truck-running-very-bad-249520/)
DodgeCTD Aug 8, 2009 08:25 PM
Okay so my truck has been down 5 weeks now.I welded a hanger on the exhaust straight to the frame and didnt disconnect my batteries [dummy] Im gettin brown smoke and serious rattle at idle and have no throttle response. I had a code p0088, rail pressure above max limit. I cleared it and it has not came back but it still runs the same. Here is what I have done so far with no difference:
1. Disconnect batteries hopin to reset computer.
2.Took rail sensor off my buddies 05 put it on mine.
3.Disconnected the fca while the truck is running, made no difference
4. Disconnected fca on my buddies 05 to see if his ran the same as mine, it didnt, not even close he still had throttle and no where near the same sound.
5. Had Bob Wagner send me an Ecm thinkin mine was fried.
6. Smarty and mp8 both removed.
Im also getting a camshaft position sensor code, I replace the sensor twice now and still got the code.
Nothing has worked or made any difference whatso ever. Im lost. Anyone have ANY idea what is going on?
rich Aug 8, 2009 08:49 PM
have removed the programmers to see if it does it stock
DodgeCTD Aug 8, 2009 09:18 PM
Yea forgot to add that, smarty is removed and so is the mp8
rich Aug 8, 2009 09:35 PM
ive welded on mine several times plus used the bed for a welding table and havent had any problems. did you check the crank sensor because the motor also reads it for the rpm's
DodgeCTD Aug 8, 2009 09:38 PM
Havnt checked that yet, but my rpms are only reading around 200...Man I would disconnect the batteries just in case cause this crap im going through now is no fun at all. I will never take this chance again. I wonder why im not getting any other codes besides p0341..
rich Aug 8, 2009 09:44 PM
hey check the wirring harness for the injectors espicially the first bank mite have a short in them
DodgeCTD Aug 8, 2009 09:47 PM
The injector harness on the side of the valve cover or the one under the valve cover? Thanks alot for the help rich.
rich Aug 8, 2009 09:49 PM
wear they go into the valve cover gasket directly to the injectors its just a rough thought
DodgeCTD Aug 8, 2009 09:51 PM
Okay I'll check it over tomorrow, i checked ecm wires today Ill look over all of it tomorrow.
Kowalski Aug 9, 2009 08:07 AM
Where did you have the ground cable attached when you welded the bracket? Check all the grounding locations and wireing harness for melted or soft spots in the wire. The welder may have used you wiring harness for grounding. Power use the path of least resistance. Had this happen on a job once and the welders fried about 10K worth of equipment when welding on the steel pipeing.
DodgeCTD Aug 9, 2009 12:20 PM
Had the ground hooked up to the exhaust tip, which was welded to the exhaust pipe, which from the exhaust pipe I was welding a steel bracket directly to the frame. So it was getting a direct connection to the frame [nonono]
txarrowhunter Aug 9, 2009 01:00 PM
Ive used all our flatbeds as welding platforms as well no problems with them. Brown smoke out of the exhaust, it sounds like a diffrent problem.
DodgeCTD Aug 9, 2009 01:31 PM
I don't have a clue..this is bs [verymad] The truck ran excellent, I parked it, welded the exhaust hanger back on, Fired it up and it was running like this. An hour after I had shut it up to begin welding this is what i got now [yuk] I appreciate the replys from everyone..Im positive welding caused it, ran great till i struck an arc on it :( I would just be extremely careful welding on it now bud, this is no fun at all, ill never weld on another vehicle again unless the battery is un hooked.
JFlory Aug 9, 2009 03:42 PM
Sounds stupid and I'm sure you already did this, but......
Have you looked over all the fuses? I know that if you arc across the alternator, it will just blow a fuse.
DodgeCTD Aug 9, 2009 03:56 PM
Doesn't sound stupid at all man, any advice is great cause i could have missed the obvious, but no i checked all the fuses. Unless there are some more that i could have missed? I didnt see any in the truck only under the hood but i pulled everyone of them and checked.
