Ok to recharge AC system using freon charging kit?
Hi,
I have had a leak somewhere in my AC system for about 5 years now. I never have taken the time to have it repaired properly & I have had freon put in the system about 3-4 times at the shop. The last time I had freon put in the system was about 2 years ago. I have no cold air right now so I know that all the freon has leaked out. Had no A/C for at least year and half now. Can't do it anymore though....it's too hot this summer. If there has been no freon in the system for about a year and half & I put freon in the system myself with a freon charging kit from autozone is it possible to cause any further damage to the a/c system? I've heard that it's possible that moisture can be in the system by now & it needs to be removed. Is there any danger in me filling the system back up with freon for the time being myself with a kit from autozone? |
Nope, best if you get a gauge set on it, but if you just fill till cold she should be OK.
Don't put anything with stop leak in it........ |
Mine developed a slight leak about 4 years ago. After adding a can of freon twice over the next year I put a can in with stopleak in it. It has been fine ever since.
Is your system TOTALLY empty or does it still have a bit of freon in it? Check by removing the cap from the low side port and poking it with a pen. Its a shrader type valve similar to a tire. Watch yourself and only do it briefly. If you get puff of freon come out you could probably get away with trying a do it yourself recharge kit.
If nothing comes out then the system is totally empty and and air has gotten in it and it will need to be evacuated with a vacuum pump before it can be recharged. Having air in the system is really bad. Its like having air in hydraulics, just doesn't work. |
Originally Posted by cLAYH
(Post 2515691)
If nothing comes out then the system is totally empty and and air has gotten in it and it will need to be evacuated with a vacuum pump before it can be recharged. Having air in the system is really bad. Its like having air in hydraulics, just doesn't work. Thanks, Mike |
Also you should know that if you use any of the non-134 kits like Duracool or Redtek that many AC shops won't touch your system after that or charge a hefty surcharge to evacuate your system as those products contaminate their equipment.
So if you think you want to take it in for service do it before you put anything in. |
You'll be fine. I did mine last week cause it got above 90 degrees here. I used a large can, it didnt completely fill my system but my air blows cold now. Before, it blew as hot as the air outside...
| All times are GMT -5. The time now is 04:34 AM. |
