-   3rd Gen High Performance and Accessories (5.9L Only) (https://www.dieseltruckresource.com/forums/3rd-gen-high-performance-accessories-5-9l-only-107/)
-   -   T/C or V/B, which first? (https://www.dieseltruckresource.com/forums/3rd-gen-high-performance-accessories-5-9l-only-107/t-c-v-b-first-233136/)
cvcook Feb 14, 2009 10:03 AM
Which fails first with horsepower upgrades, and which one (aftermarket) is needed most
mopardamo Feb 14, 2009 10:06 AM
Hello,
VB first but shortly after the TC would be smart. The VB increases line pressures, provides proper lub in Park, decreases shift slippage and several other things that are a +.
Damon
chrleb1 Feb 14, 2009 12:35 PM
It's kinda like the chicken or the egg... If you go a lot of power and you are blowing through the converter or making it slip, it will cook the oil. Also if you have lots of power with a good converter, you won't have enough line pressure in the trans and then you will start to cook the clutches.
If doing one, you better do the other.
