| PADuallyBoy |
Jan 25, 2009 11:46 PM |
Factory Tach Pickup
Right now I'm trouble shooting my tachometer. It's from RW Gauges and it uses the factory tach pickup. The tach wires just plug into the line from the pickup that are in the wire harness by the fuse box. The gauge is acting fun though, it has my idling like 250, almost like the pickup is weak. I replaced the capacitor that is in the wiring diagram. (This gauge was put in like a year or to after the truck rolled off the line, so it's older... but NOT from the factory.) So I'm thinking it's maybe the pickup by the harmonic balancer, I don't know, it's almost 1 in the morning so I have the look at it after work. Also with the pyro, also from RW... it seems slow in responce. It only has the two leads from the probe going to the back of the gauge. The probe is in the downtube, I thought I saw somewhere pyros the were calibrated for before turbo and after turbo, and the whole thing is setup the way the manual says so I don't, more trouble shooting I guess. Help would be appreciated, Thanks!
