-   1st Gen. Ram - All Topics (https://www.dieseltruckresource.com/forums/1st-gen-ram-all-topics-93/)
-   -   getrag 2wd to 4x4 (https://www.dieseltruckresource.com/forums/1st-gen-ram-all-topics-93/getrag-2wd-4x4-230820/)
freight train Jan 24, 2009 08:17 PM
getrag 2wd to 4x4
Does anyone know if it possible to take a 2wd getrag and swap the tail shaft for the transfer case adaptor? Or would I also have to change anything else? I am thinking about buying a 2wd trans because thats all I can find. I have a tail shaft piece along with a collar that slides over the splines. Thanks for all info! Robert
wannadiesel Jan 24, 2009 08:21 PM
If you already have the 4X4 tailshaft and adapter housing then you can build what you need off a 2wd trans.
PapeCAT Jan 24, 2009 08:31 PM
Yes it is possible to change a 2wd Getrag into a 4x4. The parts you will need from a 4x4 transmission are:
1.) 4x4 GetrageTailhousing
2.) 4x4 Getrag Mainshaft
